I currently have a VLAN setup for my IoT devices, which includes my raspberry pi running HA (hassbian). I’ve recently set this up (within the last few weeks) and imediatly had issues with my SONOS players not liking being on a different VLAN than their controller (iphones). Easy fix was to move the SONOS back to my normal VLAN, however this caused issues with HA not being able to discover them. I created some rules in my firewall (Ubiquiti USG), and was able to get it working, atleast it seems to be working. My problem now is I’m getting SONOS related errors in my HA log.
Does anyone have a similar setup? Any help is appreciated.
Right now, I am using the original SONOS bridge, wired into my main switch. I have 5 players, and the bridge, so I have 6 IP addresses. They all have static IP addresses, and those IP addresses are listed in my HA Sonos conifg.
My SONOS bridge is at 192.168.1.200. One of my sonos player names is “HiFi” as you will see in the error below. This is actually a SONOS connect plugged into an old Marrantz 2245. The rest of my SONOS players are Play 1s and don’t seem to be having any issues. All of the players are functioning properly and I can control them from HA and any associated automations are working fine.
The errors are:
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/media_player/sonos.py", line 338, in update
self._player.get_sonos_favorites()['favorites']
File "/home/homeassistant/.homeassistant/deps/soco/core.py", line 1369, in get_sonos_favorites
return self.__get_favorites(SONOS_FAVORITES, start, max_items)
File "/home/homeassistant/.homeassistant/deps/soco/core.py", line 1391, in __get_favorites
('SortCriteria', '')
File "/home/homeassistant/.homeassistant/deps/soco/services.py", line 181, in _dispatcher
return self.send_command(action, *args, **kwargs)
File "/home/homeassistant/.homeassistant/deps/soco/services.py", line 415, in send_command
response.raise_for_status()
File "/srv/homeassistant/lib/python3.4/site-packages/requests/models.py", line 909, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 405 Client Error: Method Not Allowed for url: http://192.168.1.200:1400/MediaServer/ContentDirectory/Control
17-03-31 12:46:53 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/lib/python3.4/asyncio/tasks.py", line 237, in _step
result = next(coro)
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/entity.py", line 204, in async_update_ha_state
"No entity id specified for entity {}".format(self.name))
homeassistant.exceptions.NoEntitySpecifiedError: No entity id specified for entity HiFi
result = next(coro)
result = next(coro)
17-03-31 12:52:00 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
