I just created a clean-slate, new installation of Home Assistant and the problem persists.
I found this in the logs
Logger: homeassistant.components.iotawatt.coordinator
Source: components/iotawatt/coordinator.py:76
Integration: IoTaWatt (documentation, issues)
First occurred: 6:58:35 AM (2 occurrences)
Last logged: 6:59:55 AM
Unexpected error fetching 10.1.1.141 data:
File "/usr/local/lib/python3.11/site-packages/httpcore/backends/asyncio.py", line 34, in read
return await self._stream.receive(max_bytes=max_bytes)
File "/usr/local/lib/python3.11/site-packages/anyio/_backends/_asyncio.py", line 1265, in receive
await self._protocol.read_event.wait()
File "/usr/local/lib/python3.11/asyncio/locks.py", line 213, in wait
await fut
asyncio.exceptions.CancelledError
File "/usr/local/lib/python3.11/site-packages/httpcore/_exceptions.py", line 10, in map_exceptions
yield
File "/usr/local/lib/python3.11/site-packages/httpcore/backends/asyncio.py", line 32, in read
with anyio.fail_after(timeout):
File "/usr/local/lib/python3.11/site-packages/anyio/_core/_tasks.py", line 118, in __exit__
raise TimeoutError
TimeoutError
File "/usr/local/lib/python3.11/site-packages/httpx/_transports/default.py", line 60, in map_httpcore_exceptions
yield
File "/usr/local/lib/python3.11/site-packages/httpx/_transports/default.py", line 239, in __aiter__
async for part in self._httpcore_stream:
File "/usr/local/lib/python3.11/site-packages/httpcore/_async/connection_pool.py", line 338, in __aiter__
async for part in self._stream:
File "/usr/local/lib/python3.11/site-packages/httpcore/_async/http11.py", line 319, in __aiter__
raise exc
File "/usr/local/lib/python3.11/site-packages/httpcore/_async/http11.py", line 312, in __aiter__
async for chunk in self._connection._receive_response_body(**kwargs):
File "/usr/local/lib/python3.11/site-packages/httpcore/_async/http11.py", line 181, in _receive_response_body
event = await self._receive_event(timeout=timeout)
File "/usr/local/lib/python3.11/site-packages/httpcore/_async/http11.py", line 195, in _receive_event
data = await self._network_stream.read(
File "/usr/local/lib/python3.11/site-packages/httpcore/backends/asyncio.py", line 31, in read
with map_exceptions(exc_map):
File "/usr/local/lib/python3.11/contextlib.py", line 155, in __exit__
self.gen.throw(typ, value, traceback)
File "/usr/local/lib/python3.11/site-packages/httpcore/_exceptions.py", line 14, in map_exceptions
raise to_exc(exc)
httpcore.ReadTimeout
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 283, in _async_refresh
self.data = await self._async_update_data()
File "/usr/src/homeassistant/homeassistant/components/iotawatt/coordinator.py", line 76, in _async_update_data
await self.api.update(lastUpdate=self._last_run)
File "/usr/local/lib/python3.11/site-packages/iotawattpy/iotawatt.py", line 79, in update
await self._refreshSensors(timespan, lastUpdate)
File "/usr/local/lib/python3.11/site-packages/iotawattpy/iotawatt.py", line 264, in _refreshSensors
response = await self._getQuerySelectSeriesIntegrate(
File "/usr/local/lib/python3.11/site-packages/iotawattpy/iotawatt.py", line 365, in _getQuerySelectSeriesIntegrate
return await self._connection.get(url, self._username, self._password)
File "/usr/local/lib/python3.11/site-packages/iotawattpy/connection.py", line 18, in get
return await self.__open(url, username=username, password=password)
File "/usr/local/lib/python3.11/site-packages/iotawattpy/connection.py", line 46, in __open
raise e
File "/usr/local/lib/python3.11/site-packages/iotawattpy/connection.py", line 37, in __open
resp = await getattr(self._websession, method)(
File "/usr/local/lib/python3.11/site-packages/httpx/_client.py", line 1757, in get
return await self.request(
File "/usr/local/lib/python3.11/site-packages/httpx/_client.py", line 1530, in request
return await self.send(request, auth=auth, follow_redirects=follow_redirects)
File "/usr/local/lib/python3.11/site-packages/httpx/_client.py", line 1631, in send
raise exc
File "/usr/local/lib/python3.11/site-packages/httpx/_client.py", line 1625, in send
await response.aread()
File "/usr/local/lib/python3.11/site-packages/httpx/_models.py", line 909, in aread
self._content = b"".join([part async for part in self.aiter_bytes()])
File "/usr/local/lib/python3.11/site-packages/httpx/_models.py", line 909, in <listcomp>
File "/usr/local/lib/python3.11/site-packages/httpx/_models.py", line 927, in aiter_bytes
async for raw_bytes in self.aiter_raw():
File "/usr/local/lib/python3.11/site-packages/httpx/_models.py", line 985, in aiter_raw
async for raw_stream_bytes in self.stream:
File "/usr/local/lib/python3.11/site-packages/httpx/_client.py", line 146, in __aiter__
async for chunk in self._stream:
File "/usr/local/lib/python3.11/site-packages/httpx/_transports/default.py", line 238, in __aiter__
with map_httpcore_exceptions():
File "/usr/local/lib/python3.11/site-packages/httpx/_transports/default.py", line 77, in map_httpcore_exceptions
raise mapped_exc(message) from exc
httpx.ReadTimeout
