Normally I access my home assistant through 192.168.0.114, but today it was changed to 192.168.0.115.
So I want this not to happen anymore.
Strange thing is that under config/network/ the file “my-network” is set to have a fixed ip : 192.168.0.114
OK. Just to be sure: I guess your accespoint is just a forwarder for your primary router, which is DHCP server? In that case you should still set the fixed IP at your DHCP server (not your acces point, but your router in that case).
If your network only has fixed IP addresses and no DHCP at all, then you are right and you should configure it in the PI settings. In that case I am not sure why it doesn’t work.
You’re SSH into the docker container. Docker is what runs hassio. You’re not in the host os which is HassOS. It only shows those 2 IP addresses because you’re inside a containerized application. It’s segmented from your actual hardware.
