IP addresses in HAOS VM NAT:ed to docker...?
I moved from Docker ti Home Assistant OS VM (Releases · home-assistant/operating-system · GitHub), to make discovery work by assigning a second nic in a different VLAN.
Now it seems like HAOS is using docker internally and maps my IP-addresses to something like 172.30.33.0, and there is no direct connection from my own networks.
The first hop is alwas the internal HAOS created network:
[core-ssh ~]$ traceroute 10.1.15.1
traceroute to 10.1.15.1 (10.1.15.1), 30 hops max, 46 byte packets
1 home-assistant.local.hass.io (172.30.32.1) 0.012 ms 0.007 ms 0.006 ms
What do I need to do to get at direct connection…??
Welcome to the Home Assistant command line.
System information
  • IPv4 addresses for eth0: 192.168.1.14/24*
  • IPv4 addresses for eth1: 10.1.15.4/24*
  • OS Version: Home Assistant OS 7.5*
  • Home Assistant Core: 2022.3.5*
  • Home Assistant URL: http://homeassistant.local:8123*
  • Observer URL: http://homeassistant.local:4357*
    [core-ssh ~]$ ifconfig
    eth0 Link encap:Ethernet HWaddr 02:42:AC:1E:21:00
  •      inet addr:172.30.33.0  Bcast:172.30.33.255  Mask:255.255.254.0*
  •      UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1*
  •      RX packets:280498 errors:0 dropped:0 overruns:0 frame:0*
  •      TX packets:1336 errors:0 dropped:0 overruns:0 carrier:0*
  •      collisions:0 txqueuelen:0*
  •      RX bytes:72582122 (69.2 MiB)  TX bytes:526606 (514.2 KiB)*
lo Link encap:Local Loopback
  •      inet addr:127.0.0.1  Mask:255.0.0.0*
  •      UP LOOPBACK RUNNING  MTU:65536  Metric:1*
  •      RX packets:4 errors:0 dropped:0 overruns:0 frame:0*
  •      TX packets:4 errors:0 dropped:0 overruns:0 carrier:0*
  •      collisions:0 txqueuelen:1000*
  •      RX bytes:530 (530.0 B)  TX bytes:530 (530.0 B)*
Please expose your actual issue (XY problem - Wikipedia)
You’re pinging for the SSH addon, apparently, which is itself a separate docker container inside HAOS, unrelated to HA proper besides sharing some folders.
The issue is that HAOS is on VLAN1 and cannot discover devices on VLAN2, although routning/communication otherwise works fine. Instead of fiddeling with mDNS a lot of threads is suggesting just to add a second nic connected to VLAN2 to HAOS, and that is what I have done, but it still does not discover devices on VLAN2.
Are your VM NICs bridged?
If they are nated, multicast discover packets won’t get through…
They are not nated. Thats why I added a second nic for a direct connection vo VLAN2.
Got it to work. Found a setting where I could enable broadcast also for the second interface.
