IP banning ineffective with Cloudflare tunnel
Hi all, had a quick question about how to configure IP banning properly when HA is running through a Cloudflare tunnel.
I started, after establishing the tunnel, that when whatever out there on the internet fails to authenticate with the server, there will be a failed login message from 127.0.0.1. I thought this was weird at first, maybe an add-on or something was misbehaving, but then I connected to a different VPN server and purposefully failed a login - but this was also logged as 127.0.0.1! Obviously this is not very useful and makes IP banning effectively useless. How can I configure HA/Cloudflared to forward the IP of who/whatever is attempting to authenticate?
This is my IP banning config:
http:
  ip_ban_enabled: true
  login_attempts_threshold: 4
  use_x_forwarded_for: true
  trusted_proxies:
    - 172.30.33.0/24
Multiple posts regarding the above issue lately. All you have to do is add 127.0.0.1/24 to the trusted proxies, then you’ll see the actual IP
  1. What installation method/OS are you running?
  2. Are you using the NabuCasa Cloud?
