I bought new IP camera which was recomended here and im unable to run it.
With ONVIF device manager it shows adress: rtsp://192.168.X.XXX:554/11 but it doesnt work in HA.
With browser it works under: http://192.168.X.XXX/web/admin.html
Define “doesn’t work”? How are you setting it up in HA? What happens? What does the log look like?
When I was setting up my IP cameras, I used VLC to test that the stream was working properly. It might be worth also installing that and trying to load the stream there to confirm if the problem is with the stream or HA or how you’re configuring it.
If I click on them I get the camera feed which is great but I’d rather just see them without having to click on them. I tried your config but I get an invalid config error.
I was struggling with the same thing.
I found this, Stream - Home Assistant , at the bottom they speak about streaming in Lovelace. All you still need to do is add the below lines to your lovelace.
Did you ever figure this out? Going through the same thing with a different camera right now. Have the rtsp address for live stream but can’t figure out the http address for still images?
