I have bought a Reolink ip-camera and this is connected to my 2.4ghz wifi network.
I can look at the feed using the Reolink app on my phone and the Reolink windows program.
When i try to add it to Home Assistant the problems start.
The integration is found so Home Assistant knows the camera is on the network.
When i try to connect it asks for following info: Username, Password, Host, Port and the option to use HTTPS.
Username and pasword are setup in the app on installation.
The problem seems to be the Host and Port.
I have the correct ip-adress ( autofilled by Homeassistant and confirmed in router ).
The port i have inserted in the Reolink windows program and is known aswell.
The error i keep getting is " Failed to connect, check the IP address of the camera ".
Hi there. If this is what im thinking it is, this will be amazing. What i think it is, is that you type that in somewhere and it will give you the exact port that the camera is using. If im right. Where do you type this in to get the port number?
Any computer running Linux. Including the advanced ssh & web terminal page (everyone should install that!)
Here is a sample output
nmap -p0-65535 192.168.20.33
Starting Nmap 7.80 ( https://nmap.org ) at 2024-04-25 17:35 NZST
Nmap scan report for 192.168.20.33
Host is up (0.029s latency).
Not shown: 65531 closed ports
PORT STATE SERVICE
21/tcp open ftp
22/tcp open ssh
80/tcp open http
443/tcp open https
554/tcp open rtsp
Nmap done: 1 IP address (1 host up) scanned in 10.21 seconds
So, to install nmap on your Mac Mini, you’ll need to either install nmap this way: Apple Mac OS X | Nmap Network Scanning or using Homebrew (personally, I would go the Homebrew route).
ok I finally got it but it doesn’t look the same as yours
yours show ssh, https,rtsp
Host is up (1.0s latency).
Not shown: 65530 closed tcp ports (conn-refused)
PORT STATE SERVICE
0/tcp filtered unknown
21/tcp open ftp
23/tcp open telnet
80/tcp open http
8888/tcp open sun-answerbook
30000/tcp open ndmps
