IPAD 3 IOS 9.3.5 support or not?
Browser engine on iOS 9.3.5 is too old for lovelace UI.
but i found a working solution:
Solution: 2 steps
  1. the last version of homeassistant docker container that kind of works with workaround is: 2021.12
    Next version 2022.1 does not, even with workaround. 2021.12 has working knx integration
  2. login token does still not work with 2021.12 so you need to switch to an alternatin authentication method, like trusted networks
Here is what you need to do (in this order !!!)
sudo docker pull homeassistant/home-assistant:2021.12
sudo docker run -d
–restart unless-stopped
–name=homeassistant
-h homeassistant
-e PUID=1001
-e PGID=1001
-e TZ=CET
–net=host
-v homeassistant:/config
  1. connect on a PC and configure a user (doesn’t work with trusted networks)
    http://homeassistant.local:8123
  2. enable trusted networks in configuration.yaml (insert first 5 rows end change to your net adress)
sudo nano /var/lib/docker/volumes/homeassistant/_data/configuration.yaml
homeassistant:
auth_providers:
- type: trusted_networks
trusted_networks:
- 192.168.8.0/24
Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
Text to speech
tts:
  • platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
knx: !include knx.yaml # if you need knx integration
> Blockquote
  1. (optional) add your knx configuration (no need for configuring IP interface or IP router)
    this is my knx.yaml:
#knx:
light:
  • name: Deckenlicht_Glastüre
    address: 0/0/4
  • name: Bar_Licht1
    address: 0/0/10
  • name: Wandlicht_Glastüre_Stiege
    address: 0/0/11
cover:
  • name: Raffstore_Küche_Hoch_Tief
    move_long_address: 1/0/12
  • name: Raffstore_Küche_Stop
    move_long_address: 1/0/13
  • name: Raffstore Küche Pos1
    position_address: 1/0/27
  • name: Raffstore Küche Pos2
    position_address: 1/0/28
switch:
  • name: Sofa_Stehlampe_steckdose_rechts
    address: 0/0/3
  • name: Alles_Aus1
    address: 0/5/1
  • name: Stiege_Steckdose_Christbaum
    address: 2/0/11
  • name: Strommessung_all_abfragen
    state_address: 5/0/0
    type: “active_energy”
    state_class: “total_increasing”
  1. restart homeassistant
    (ether via web browser on PC or via:
    docker restart homeassistant
  2. open safari on your iPad2 (iOS 9.3.5) and open the url:
    select your user and have fun!
Hi all, I’m using HA Dashboard and appdaemon to get an old ipad2 (9.3.5) displaying my HA days as well as a radar. I’m pretty happy with it. The garage door works as a button as well. It’s on 24/7.
