iPhone doesn't find homekit ha bridge
I am trying to setup homekit but my iPhone doesn’t find the bridge.
Everything seems to be ok on HA side.
2019-11-07 13:11:50 DEBUG (SyncWorker_3) [pyhap.characteristic] set_value: Name to Home Assistant Bridge
2019-11-07 13:11:50 DEBUG (SyncWorker_3) [pyhap.characteristic] set_value: SerialNumber to default
2019-11-07 13:11:50 DEBUG (SyncWorker_3) [pyhap.characteristic] set_value: FirmwareRevision to 0.100.2
2019-11-07 13:11:50 DEBUG (SyncWorker_3) [pyhap.characteristic] set_value: Manufacturer to Home Assistant
2019-11-07 13:11:50 DEBUG (SyncWorker_3) [pyhap.characteristic] set_value: Model to Bridge
2019-11-07 13:11:50 DEBUG (SyncWorker_3) [pyhap.characteristic] set_value: SerialNumber to homekit.bridge
2019-11-07 13:13:58 INFO (SyncWorker_14) [pyhap.accessory_driver] Storing Accessory state in `/config/.homekit.state`
2019-11-07 13:13:58 INFO (SyncWorker_14) [homeassistant.components.homekit.util] Pincode: 639-68-038
2019-11-07 13:13:58 DEBUG (SyncWorker_14) [homeassistant.components.homekit] Driver start
2019-11-07 13:13:58 INFO (SyncWorker_12) [pyhap.accessory_driver] Starting the event loop
2019-11-07 13:13:58 DEBUG (SyncWorker_12) [pyhap.accessory_driver] Not setting a child watcher. Set one if subprocesses will be started outside the main thread.
2019-11-07 13:13:58 INFO (SyncWorker_0) [pyhap.accessory_driver] Starting accessory Home Assistant Bridge on address 192.168.1.XX, port 51827.
2019-11-07 13:13:58 DEBUG (SyncWorker_0) [pyhap.accessory_driver] Starting event thread.
2019-11-07 13:13:58 DEBUG (SyncWorker_0) [pyhap.accessory_driver] Starting server.
2019-11-07 13:13:58 DEBUG (SyncWorker_0) [pyhap.accessory_driver] Starting mDNS.
2019-11-07 13:13:59 DEBUG (SyncWorker_0) [pyhap.accessory_driver] Starting accessory.
2019-11-07 13:13:59 DEBUG (SyncWorker_0) [pyhap.accessory_driver] AccessoryDriver started successfully
2019-11-07 13:13:59 DEBUG (MainThread) [homeassistant.components.homekit_controller.config_flow] Discovered device Home Assistant Bridge (Home Assistant Bridge - 12:28:XX:XX:XX:XX
I have had homekit component enabled before, long time ago. I have tried to reinstall the homekit component and removed the homekit.state file many times. I also removed home app from my phone and relogged to iCloud.
I have the pincode but nothing shows up on home app.
What could cause this?
Thank you!
Having the same problem. Anyone have any ideas?
same problem here!
I did everything as it shows on tutorial and my homekit cannot find the HA.
