I just switched from Hass.io to HomeAssistant (via Docker) and when I enter in the HomeKit setup code into the Apple Home app, the accessory isn’t appearing. I suspect this might have to do with my docker-compose setup, so I’m including it just in case.
homeassistant:
container_name: homeassistant
restart: always
image: homeassistant/home-assistant
devices:
- /dev/ttyUSB0:/dev/ttyUSB0
- /dev/ttyUSB1:/dev/ttyUSB1
- /dev/ttyACM0:/dev/ttyACM0
volumes:
- ${USERDIR}/docker/homeassistant:/config
- /etc/localtime:/etc/localtime:ro
- ${USERDIR}/docker/shared:/shared
ports:
- "8123:8123"
privileged: true
environment:
- PUID=${PUID}
- PGID=${PGID}
- TZ=${TZ}
labels:
- "traefik.enable=true"
- "traefik.backend=homeassistant"
- "traefik.frontend.rule=Host:homeassistant.${DOMAINNAME}"
- "traefik.port=8123"
- "traefik.docker.network=traefik_proxy"
- "traefik.frontend.headers.SSLRedirect=true"
- "traefik.frontend.headers.STSSeconds=315360000"
- "traefik.frontend.headers.browserXSSFilter=true"
- "traefik.frontend.headers.contentTypeNosniff=true"
- "traefik.frontend.headers.forceSTSHeader=true"
- "traefik.frontend.headers.SSLHost=noakland.com"
- "traefik.frontend.headers.STSIncludeSubdomains=true"
- "traefik.frontend.headers.STSPreload=true"
- "traefik.frontend.headers.frameDeny=true"
