Ddiaz
January 25, 2021, 3:03am
1
Trying to learn the best way for presence detection. There is an integration, iphonedetect, located here: https://github.com/mudape/iphonedetect
Added this to my configuration.yaml:
- platform: iphonedetect
consider_home: 60
scan_interval: 12
new_device_defaults:
track_new_devices: true
hosts:
hostname1: 192.168.1.3
hostname2: 192.168.1.9
When I check the configuration if gives the following error:
Platform error device_tracker.iphonedetect - Integration ‘iphonedetect’ not found.
Here are the particulars of the install:
Raspberry Pi 3 B+
Version
2021.1.5
Installation Type
Home Assistant OS
Development
false
Supervisor
true
Docker
true
Virtual Environment
false
Python Version
3.8.7
Operating System Family
Linux
Operating System Version
5.4.79-v7
CPU Architecture
armv7l
Timezone
America/New_York
Ddiaz
January 25, 2021, 3:29am
2
Just saw that this requires HACS to work.
Tinkerer
(aka DubhAd on GitHub)
January 25, 2021, 7:45am
3
It doesn’t require HACS, but it does require you to install it
You need to manually, or using HACS, copy the required files to /config/custom_components/iphonedetect
then restart HA
As Tinkerer said it doesn’t require HACS. You MAY need to add it manually to the device tracker yaml file though… It didn’t automatically add it for me but the component works great
Can you give me an example of how to use this? I have it downloaded, and the entries in my configuration.yaml.
I just don’t know how to reference the entity. Nothing shows up when I try to add a card.
I have added static IPs for the devices in my router.
Thank you
It’s configured via the GUI now
wptracy
(William Tracy)
August 26, 2023, 1:27pm
7
You have to create a directory called iphonedetect in /root/config/custom_components and add these four files from https://github.com/mudape/iphonedetect/tree/master/custom_components/iphonedetect
init .py const.py manifest.json
pycache device_tracker.py
/root/config/custom_components/iphonedetect
[core-ssh iphonedetect]$ ls
