IPMI Sensors
i’m having the same issue all installed with no issues but the custom integration is not starting
Ok. I installed the server by placing it on the addons folder. Refreshed HA and started the AddOn… All went perfect. Then installed the connector and configured the server parameters. It gathered some information but no sensors, fans, voltages. Only model and Power (which my server returns empty, but that’s another issue with my setup).
I debugged the server a couple hours and found out that there’s a bug in a condition. I opened an issue in the repo so the maintainer can fix it (LINK to issue)
So far everything is working perfectly.
I’m using these versions:
Home Assistant 2023.8.4
Supervisor 2023.08.1
Operating System 10.5
Frontend 20230802.1 - latest
I don’t know how to set up this integration, I get no connect to intel Bmc immediately, screenshots would be helpful,
When I use the Ipmi Browser I get a connection when I set the “Cipher” field
thanks
@IOT_Ninja , THANK YOU SO MUCH!!!
