To get an IPv6, I’ll need my dhcp client to provide a particular DUID in its solicitation. I’m a bit confused because I notice that there are folders relating to ifup but no /etc/network/interfaces file; the logs refer to systemd and NetworkManager when I statically configure ipv6 but I can’t find any configuration files for these 2 components anywhere in the file system.
I think I’ll be able to manage if a generous soul could tell me where to put my hands ^^.
I know HAOS uses network-manager for most of its IP management.
If you can get into your HAOS linux console/shell you can try nmcli out to set parameters that influence DUID (I don’t use DHCPv6, so don’t have any experience).
First find out what the network-manager connection profile is being used: nmcli con show
You should see something like:
NAME UUID TYPE DEVICE
Supervisor enp0s3 c14e9fbc-98dc-49e0-b65e-c39d18abdef9 ethernet enp0s3
Then you can look at all the possible parameters: nmcli con show "Supervisor enp0s3"
You should see some parameters in the output like:
ipv6.dhcp-duid: --
ipv6.dhcp-iaid: --
You can also read this page (search on “duid”) to see how these parameters influence duid.
The configured information should be stored at /etc/NetworkManager/system-connections/Supervisor enp0s3, but I have found that it often doesn’t persist across reboots. If you find this is the case I suppose you could create a github issue and see what the devs say.
