Hi, I’ve made a custom_component to take control over notifications I’m sending to mobile devices.
How can you notify?
- Notify only people present at home. (
only_home) - Notify only people away from home. (
only_away) - Notify people that just arrived home. (
just_arrived) - Notify people that just left home. (
just_left) - Notify people that are present at home for particular time. (
staying_home) - Notify people that are away from home for particular time. (
staying_away) - Try to notify people at home, but if none – notify people away. (
only_home_then_away)
How it works
Just like group notify platform it combines multiple notification services with presence detection entities:
notify:
- platform: iq_notify
pairs:
- entity: binary_sensor.presence_he
service: his_iphone
- entity: binary_sensor.presence_she
service: her_iphone
Will create new service called notify.iphones you can use for regular automations.
Configuration reference
notify:
- platform: iq_notify # the platform to use
name: iphones # alias name for notify.{name}
time: 2 # time offset in which we assume someone "just left/arrived" or "is staying"
pairs: # a list of presence entities are corresponding notify services
- entity: binary_sensor.presence_he # presence entity id #1
service: his_iphone # notify service to use for above entity, without domain (notify.)
- entity: binary_sensor.presence_she # presence entity id #2
service: her_iphone # notify service to use for above entity, without domain (notify.)
time(defaults to 2)
In minutes as offset to analyze if someone “just left/arrived”. If someone will be at given state longer than giventime– he/she won’t be considered as someone that “just …”. This is also used for “staying home/away”. Someone must be minimum oftimein given state to be considered as “staying …”.
entity(required)
ID of any entity that state for “present” isonorhomeandoffornot_homefor “away”.
Can beinput_boolean,binary_sensor,group,switch,device_trackeretc.
service(required)
Is a service to use for notification withoutnotify.domain.
Example automations
Send notification only to people that are present at home.
- alias: 'Notify: on garbage disposal'
platform: state
entity_id: calendar.garbage_disposal
to: 'on'
condition:
condition: state
entity_id: binary_sensor.people_present
state: 'on'
- service: notify.iphones
title: Garbage disposal
message: "{{ states.calendar.garbage_disposal.attributes.message }}"
mode: only_home
If there is someone present – notify people that are present that today is the day of garbage disposal. We don’t want to notify people that are away, because they wouldn’t take the garbage out in front of the house.
Send notification to last person who just left home and this way armed the alarm.
automation:
- alias: 'Alarm: arm away when everyone left'
platform: state
to: 'off'
- service: alarm_control_panel.alarm_arm_away
entity_id: alarm_control_panel.alarm
- alias: 'Alarm: send notification on arming'
- platform: state
to: 'armed_away'
title: Alarm
message: Alarm has been armed.
mode: just_left
First automation tracks if everyone left home. If so – arms the alarm. After alarm is armed – second notification notifies only the person who “just left” that the alarm was armed successfully. The last person is responsible for arming the alarm.
Notify only people that are home, but if there are none – notify those away.
automation:
- alias: 'Door: remind on garage door kept opened'
platform: state
entity_id: binary_sensor.garage_door_contact
to: 'on'
for: '00:05:00'
title: Garage door
message: Garage door kept opened for 5mins.
mode: only_home_then_away
Will let know inmates that are home about the door that are not closed, but should be. They are home so they can close it. Otherwise if no one is home – let everyone know, because it might be a security breach.
Download
You can get the component here:
How to install
- Clone repository into
$HASS_HOME/custom_components/iq_notify. - Update your
configuration.yaml.
Issues
This platform is not yet 100% tested. Any suggestions and issue reports are welcome!
