TLDR: Seeking recommendations for Coordinator, IR Bridge and RF Bridge. Need to work with HASS in QNAP Docker and Tradfri. As simple as possible ploise.
LV: I’ve got a basic Tradfri set up through a few rooms of the house using the Ikea hub/gateway. I was drawn to Home Assistant thinking I could overcome some limitations of this gear… particularly the motion sensor logic… and bring in some audio/video control integration. This has actually become my main interest. I use Logitech Media Server (LMS) running on a QNAP TS-451+ NAS, and Squeeezeboxes, Sonos and AirPlay AV receivers. Some of these service speakers in outside areas, so conventional universal remotes are not convenient, despite me having an IR relay system between everything.
I saw the WiFi to IR “universal remote” smart devices and thought one would be worth bringing into this cobbled together arrangement to assist usability. I briefly noted something about Local Tuya and thought that sounded great, so bought an Arlec (Antsig) branded Tuya IR blaster from Bunnings. I got it set up mostly as per the instructions, though used the Tuya app on Android rather than the branded app. Overall, the Tuya WiFi blaster has worked well.
I created a few scenes and got those across to Home Assistant and HomeRemote. Home Assistant is running in a Docker container on the Qnap. These scenes, while a bit limiting, are adequate and also work acceptably.
However it’s cloud serviced by Tuya, and I don’t really want it as a weakness on my network. Blocking the device from accessing the internet kills the ability to operate it. Looking at Local Tuya more closely, I quickly realised it was unlikely to work with the Tuya IR device. I have received pretty solid confirmation in this regard, though am happy to hear otherwise.
I thought maybe I should have bought Broadlink. Then there’s Sonoff, plus re-flashed versions of them all. My Tuya blaster has an ESP chip, so Tasmota is a possibility?
However flashing would be towards the limits of my brain capacity / time allowance matrix. Flashed hardware also appears to make the IR learning process hard work. I have a fair swag of codes I want to be available. I am also a HA noob and an easily overwhelmed by the level of computer skills often outlined in these circles.
Sooooo… if you have read this far, I am looking for direction. Suggestions for hardware, technical topography, ideas and musings.
I have no HA coordinator yet, but figure the right one will assist. I can run additional technologies in docker such as Mosquitto (or whatever). I’d also like to add 433Mhz RF Universal Remote too, as I have a heap of RF controlled wall socket adapters. Either a single purpose RF unit or one with IR included is fine… I am happy to ditch the Tuya.
I have tried to fish for my answers prior to posting, but with so many possible directions it is easy to become overwhelmed.
Cheers, Steve
