IR Blaster with IR OUT Port?
Hi are there any compatible IR blasters with an IR out port for extensions? the only one i can find is the harmony hub, which of course is defunct and wont last forever. don’t really want to DIY anything just need a little box with an IR Out port.
Whats the use case here?
We use to use multiple broadlink device’s and at one point we also used Ir extenders that simply detected the origin iIR signal via a receiver and passed it to a transmitter - via wired connections. Since we moved we have just used harmony.
EDIT:
This is similar to what we used in the past:
https://www.amazon.com/OBVIS-Infrared-Extender-Repeater-Emitters/dp/B099ZPJ6BW/
My HDMI switcher for my PC monitors uses the same IR codes as my AC unit.
So when i switch sources on my HDMI switcher, The AC unit does all kinds of stupid stuff.
The HDMI switcher has an IR IN port for it’s extender, so i want to connect directly from a device that has an IR out port to the HDMI switchers IR In port and avoid blasting the room with IR signals that my AC unit doesn’t like.
If something like the Broadlink RM3/RM4 had an IR out port that would be perfect.
