I want to switch most of my devices from WiFi to something wired.
Do you guys know of an option for a wired IR blaster?
You’d be looking at a project like this to try copy as I don’t think there are many options for ethernet based ones that work on a LAN connection as they are via stand alone HDMI switches otherwise.
esp32 ethernet board of choice and a IR diode and receiver
Thanks! I would like to find some already made solution, but if nothing comes up I might have to resort to this.
Global Caché should have a solution for LAN to IR blaster, it’s not cheap though.
https://www.home-assistant.io/integrations/itach/
aqara hubs have built in IR, you could add it via homekit but i’m not sure if homekit will expose the IR Blaster
