IR FAN (Dyson AM07) Harmony Full Control
Hello, i wanted to include my Dyson Fan into HASSIO. Initially i thought about opening it up, and connecting an arduino to it… but i’m too chicken to try it out… fear of breaking and lack of knowledge…
So, i tried to include it into HASSIO using my Harmony Bridge. It took some time to figure it all out, but im very happy with the function right now.
It basically gives you 2 Sliders (1 for Speed, 1 for Timer) & 2 Switches (1 for Power, 1 for Oscilliate)
I tried to copy the functionality and logic of the original remote with several automations.
For example: You can turn on the Fan by just pressing oscillate button. Or by just pressing Fan Up button. This is all represented now and for now i have not found a breaking issue :slight_smile:
Functions:
Turn on Fan via Slider or Switch (Fan automatically goes to the desired Level)
Turn On / Off Ocillation (Power On is toggled as well from Off state)
Adjust Speed
Turn Off via Slider or Button (The Fan will always go down to 1 first, and then turn off)
Timer is not using the built in Dyson Timer, but actually a more flexible Timer builtin Hassio
I’d like to add a countdown timer as well so you can see how much time is left… But so far every attempt has failed. Any ideas welcome :slight_smile:
However, it requires you to ditch the remote, as this is IR based, and cannot report outside states into HASSIO.
This is how it looks right now:
Capture
As I am still very much new to HASSIO, have no coding experience and am constantly wondering why something works or doesnt work… i’d be very happy for some good advice on how to streamline all of these below:
So this is what you need to do to copy it:
configuration.yaml
#Dyson LivingRoom
# Define input_slider
input_slider:
  livingroom_fanspeed:
    initial: 0
    min: 0
    max: 10
    step: 1
    icon: mdi:fan
  livingroom_fantime:
    initial: 0
    min: 0
    max: 120
    step: 5
    icon: mdi:timer
#Switches
    input_boolean:
      livingroomfanpower:
        initial: off
        icon: mdi:power
      livingroomfanoscillate:
        initial: off
        icon: mdi:code-tags
automations.yaml
# Dyson LR FanSpeedUP Slider
- action:
  - data_template:
      command: FanSpeedUp
      delay_secs: '0.25'
      device: '37767707'
      entity_id: remote.living_room
      num_repeats: '{{ trigger.to_state.state | int - trigger.from_state.state | int
    service: remote.send_command
  alias: FanSpeedUpDL
  condition:
    condition: and
    conditions:
    - condition: template
      value_template: '{{ trigger.from_state.state | int < trigger.to_state.state
        | int  }}'
      value_template: '{{ 0 < trigger.from_state.state | int }}'
  - entity_id: input_slider.livingroom_fanspeed
    platform: state
# Dyson LR FanSpeedDOWN Slider
- action:
  - data_template:
      command: FanSpeedDown
      delay_secs: '0.25'
      device: '37767707'
      num_repeats: '{{ trigger.from_state.state | int - trigger.to_state.state | int
  alias: FanSpeedDownDL
  condition:
    condition: and
    conditions:
      value_template: '{{ trigger.from_state.state | int > trigger.to_state.state
        | int }}'
      value_template: '{{ 0 < trigger.to_state.state | int }}'
    platform: state
# Dyson LR Oscillate
- action:
  - data_template:
      command: Oscillate
      delay_secs: '0.25'
      device: '37767707'
  alias: OscillateDL
  - entity_id: input_boolean.livingroomfanoscillate
    platform: state
#Dyson LR Speed up to sliderstate from 0
- action:
  - data_template:
      command: FanSpeedUp
      delay_secs: '0.25'
      device: '37767707'
        - 1 }}'
  alias: Turn on from zero
  condition:
    condition: and
    conditions:
      value_template: '{{ trigger.from_state.state | int < 1 }}'
      value_template: '{{ trigger.to_state.state | int > 1 }}'
    platform: state
#Dyson LR Turn on to 1 from 0
- action:
  - data_template:
      command: PowerToggle
      delay_secs: '0.25'
      device: '37767707'
  alias: Turn on to one
  condition:
    condition: and
    conditions:
      value_template: '{{ trigger.to_state.state | int < 2 }}'
    platform: state
#Dyson LR Turn Down Speed to 1 and then turn off
- action:
  - data_template:
      delay_secs: '0.25'
      device: '37767707'
  - data_template:
      delay_secs: '0.25'
      device: '37767707'
  alias: Turn off when zero
  condition:
    condition: template
    value_template: '{{ trigger.to_state.state | int < 1 }}'
    platform: state
#Dyson LR Turn On Power if Oscillate is turned on
- action:
      entity_id: input_boolean.livingroomfanpower
  alias: OscillatePower
    platform: state
    to: 'on'
#Dyson LR Turn Off Oscillate if Power is turned off
- action:
  - service: input_boolean.turn_off
    platform: state
    to: 'off'
#Dyson LR Turn Slider to 0 if PowerButton is Off
- action:
  - service: input_slider.select_value
    data_template:
      value: '0'
  alias: PowerOff
    platform: state
    to: 'off'
#Dyson LR Turn Off Power if Slider is turned to 0
- action:
  alias: PowerOff
    platform: state
    to: '0.0'
#Dyson LR Turn Slider to 1 if Power is on
- action:
    data_template:
      value: '1'
  alias: PowerOn
  condition:
    condition: template
    value_template: '{{ states.input_slider.livingroom_fanspeed.state | int < 1 }}'
    platform: state
    to: 'on'
#Dyson LR Turn on Power if Slider > 1
- action:
  alias: PowerOn
    platform: state
  condition:
    condition: template
    value_template: '{{ trigger.to_state.state | int > 0 }}'
#Dyson LR Timer LR Dyson
- action:
  - delay: '00:{{ states.input_slider.livingroom_fantime.state | int }}:00'
  alias: PowerOff Timer
    platform: state
    entity_id: input_slider.livingroom_fantime
  condition:
    condition: template
groups.yaml
#LivingRoomFan
card_dysonlr:
  name: Dyson Wohnzimmer
  entities:
    - input_boolean.livingroomfanoscillate
    - input_boolean.livingroomfanpower
    - input_slider.livingroom_fanspeed
    - input_slider.livingroom_fantime
Great idea! I’m going to give this a try this weekend. Thanks for sharing!!
Finally was able to add the desired timer :slight_smile:
Mainly using the idea of tboyce1 Stopwatch. Slightly modifiying it, and using a 3rd Sensor to display the remaining time in minutes.
Capture
The addtiional code:
configuration.yaml
input_boolean:
  stopwatch:
    initial: off
  dummy:
    initial: off
groups.yaml
card_dysonlr:
  entities:
    - sensor.timedyson
customize.yaml
> sensor.timedyson:
>   icon: mdi:timelapse
automations.yaml
- alias: Stopwatch start
    platform: state
    entity_id: input_boolean.stopwatch
    to: "on"
    - service: input_boolean.toggle
      entity_id: input_boolean.dummy
- alias: Stopwatch stop
    platform: state
    to: 'off'
- alias: Stopwatch update
    platform: time
    seconds: '/30'
  condition:
    condition: state
    state: 'on'
######################################################Dyson LR Turn Timer Slider to 0 if PowerButton is Off###########################################
- action:
    data_template:
      value: '0'
  alias: PowerOff
    platform: state
    to: 'off'
############################################################### TURN ON STOPWATCH IF TIMER IS BIGGER THAN 0 ############################################
- action:
  alias: PowerOn
    platform: state
  condition:
    condition: template
################################################################ TURN OFF STOPWATCH IF POWER IS OFF ####################################################
- action:
    platform: state
    to: 'off'
sensors.yaml
    sensors:
      stopwatch:
        friendly_name: "Stopwatch"
        value_template: >
          {% if is_state('input_boolean.stopwatch', 'on') %}
            {{ (now() - states.automation.stopwatch_start.attributes.last_triggered).total_seconds() | int }}
          {%-elif is_state('sensor.stopwatch', 'unknown') %}
            0
          {% else %}
            {{ states.sensor.stopwatch.state }}
          {% endif %}
        unit_of_measurement: 'sec'
        entity_id:
          - automation.stopwatch_start
          - automation.stopwatch_update
          - automation.stopwatch_stop
    sensors:
      timedyson:
        friendly_name: "Time Left"
        value_template: '{{ (states.input_slider.livingroom_fantime.state | int - states.sensor.stopwatch.state | int / 60)| round }}'
        unit_of_measurement: 'min'
So I took the general idea but decided to modify to make a much simpler implementation. This version requires just 2 scripts, and 2 automations. Also uses a default fan speed when turning the switch on. I didn’t include a timer, as I never use that feature myself.
EDIT: latest version has a breaking change from input_slider to input_number. Updated with change.
Input_Number:
  dyson_fan_speed:
    icon: mdi:fan
    min: 0
    max: 10
    step: 1
Input_Select (for default speed):
  default_fan_speed:
    name: Default Fan Speed
    icon: mdi:speedometer
    options:
      - 1
      - 2
      - 3
      - 4
      - 5
      - 6
      - 7
      - 8
      - 9
      - 10
Switch Template:
  dyson_fan_power:
    value_template: "{{ states('input_number.dyson_fan_speed') | int > 0 }}"
    turn_on:
      service: script.turn_on
      entity_id: script.dyson_on
    turn_off:
      entity_id: script.dyson_off
Scripts:
  dyson_on:
    sequence:
      - service: remote.send_command
        entity_id: remote.bedroom
          device: "37710632"
          command: "PowerToggle"
      - service: input_number.select_value
        data_template:
          entity_id: input_number.dyson_fan_speed
          value: '{{ states.input_select.default_fan_speed.state | int }}'
          device: "37710632"
          command: "Oscillate"
  dyson_off:
    sequence:
        data_template:
          value: 0
      - delay:
          seconds: 5
          device: "37710632"
Automations:
  - alias: "Dyson Fan Speed Up"
    initial_state: on
      - platform: state
    condition:
      condition: and
      conditions:
          value_template: '{{ trigger.from_state.state | int < trigger.to_state.state | int }}'
        data_template:
          command: FanSpeedUp
          delay_secs: '0.25'
          device: '37710632'
          num_repeats: >
            {% set from_speed = (trigger.from_state.state | int) %}
            {% set to_speed = (trigger.to_state.state | int) %}
            {% if  from_speed == 0 %}
              {% set repeats = (to_speed - 1) %}
            {% else %}
              {% set repeats = to_speed - from_speed %}
            {% endif %}
            {{repeats}}
  - alias: "Dyson Fan Speed Down"
    initial_state: on
      - platform: state
    condition:
      condition: and
      conditions:
          value_template: '{{ trigger.from_state.state | int > trigger.to_state.state | int }}'
        data_template:
          delay_secs: '0.25'
          device: '37710632'
          num_repeats: >
            {% if  to_speed == 0 %}
              {% set repeats = 10 %}
            {% else %}
              {% set repeats = from_speed - to_speed %}
            {% endif %}
            {{repeats}}
Group:
  dyson_fan:
    control: hidden
    view: no
    entities:
      - switch.dyson_fan_power
      - input_select.default_fan_speed
      - input_number.dyson_fan_speed
      - script.dyson_oscillate
My Dyson AM08 - works with harmony perfecty to do the initial turn-ON or any other intial command. It i received by Dyson .
But the OFF command (or any second command) is being ignored… It only works when I bring Dyson right next to harmony or its own remote for that matter. And need to point EXACTLY at the base of it. Only then it turns off.
So the first command works with pointing the remote vaugly in any direction and harmony can turn it on as well from the corner of the room, but off only works with exact pointing…
did anybody experience the same issue?
Yes same for me. The On command is easily recognized. All the other require close proximity. What works well are the small ir externer you can Plug into the Hub
My hub happens to be very close to the fan and maybe that’s the reason I have no problems with it. Maybe it needs a delay in between commands?
Even the original remote only works if you point it directly at the sensor on the bottom of the fan, and you are at least 2-3meters close to it…
Hello Jer78, i would like if ti’s possible to adapt your Dyson automation from the IR to Wifi command.
I tried to do it myself but of course from the “data_template” line nothing’s working.
I can set the fan speed from the dev tools Dervice Data with this kind of command(working from 1 to 10, 0 don’t turn off the fan):
  "entity_id": "fan.salon","speed":"5"
How could i adapt this kind of command to your automations?
Here are my settings:
  dyson_fan_speed:
    icon: mdi:fan
    initial: 0
    min: 0
    max: 10
    step: 1
   initial_state: on
     - platform: state
   condition:
     condition: and
     conditions:
     - service: fan.set_speed
       entity_id: fan.salon
       data_template:
         delay_secs: '0.25'
         num_repeats: >
           {% else %}
           {% endif %}
           {{repeats}}
   initial_state: on
     - platform: state
   condition:
     condition: and
     conditions:
       data_template:
         delay_secs: '0.25'
         num_repeats: >
           {% else %}
           {% endif %}
           {{repeats}}
Thank you
@Romquenin
So for the Wifi connected fans, it should be much easier to do. Without having one myself, I can’t test this, but this should work.
Input Number (since there’s a power on/off function, we won’t need the 0 setting)
  dyson_fan_speed:
    icon: mdi:fan
    min: 1
    max: 10
    step: 1
We will need 2 different automations. One to update the fan and the other to update the input_number. Let’s try this first with templates in the automation but if it doesn’t work, we may need to make template sensors instead.
 - alias: "Dyson Fan Speed From Input Boolean"
   initial_state: on
     - platform: state
   condition:
     condition: and
     conditions:
         value_template: '{{ (trigger.to_state.state | int) != (states.fan.salon.attributes.speed|int) }}'
       data_template:
         speed: '{{states.input_number.dyson_fan_speed.state|int}}'
 - alias: "Dyson Fan Speed From Component"
   initial_state: on
       value_template: '{% if (states.fan.salon.attributes.speed|int) != (states.input_number.dyson_fan_speed.state|int) %}true{%endif%}'
     - service: input_number.set_value
       data_template:
         value: '{{states.fan.salon.attributes.speed|int}}'
Jer78 it works perfectly fine, you are amazing!!
Thank you very much again for sharing your knowledge, i will learn from this code and post my config for the other users.
Merci beaucoup!
@Romquenin You’re quite welcome. Glad to be of assistance!
Hi @AlmostSerious
Thanks for your share!!
But can you help me convert it to RF fan with command boardlink_send??
Hi CloudHoang,
i’m not sure how the Broadlink is working within home assistant, as i do not have this device. However, you should be all set by just changing the “ACTION” part from Harmany to your Broadlink Device command.
So instead of telling Harmony to “press the button” FanSpeedUp 4 times, you just tell it to your Broadlink device. All the others steps should be the same.
Hi @AlmostSerious
Thanks for you reply.
I not sure but I can control via boardlink as the command below:
sequence:
  - service: switch.broadlink_send_packet_192_168_137_84
      packet: #send a packet
        - "JgBAAGkAA..."
Base on your code… I can change with there line below?
Am I right???
Thanks!
HI @Jer78
Thanks for your modified code…
However, my apologize, I dont know how to user your code.
Can you help me like the 1st topic of @AlmostSerious did…
Thanks :slight_smile:
@CloudHoang I’m not familiar with Broadlink either. What commands would you send? Is this the component?
https://home-assistant.io/components/switch.broadlink/
Hi @Jer78
I just need help about the code only :slight_smile:
Because I new on this so I dont know where to input yr code…
I tried it but most of time I got error :frowning:
@CloudHoang But I can’t help if I don’t know what this component is or does. I’d suggest you first get the commands working in a script and then paste them here. After that we can assemble them. But without knowing how or what this Broadcom Switch does I can’t help.
Hi @Jer78
Thank for your help :slight_smile:
I has tried to add your custom code last night but still not work.
On HA show me that the switch config is wrong. need to check again.
Base on your code, I can change the script as below to control my device via Boardlink
Most of time I can control with this
        - "packet code"
