IR (Infrared) USB Receiver (or Odroid N2+ built in receiver)
I have an USB IR Receiver that looks like the picture below. I see it in the hardware portion of HA as well. Information from that screen copied below. I’d like to be able to use the device to “listen” for IR signals. Is that possible?
Alternatively, I’m running HA on an Odroid N2+ that has an IR receiver. I’d be happy to use it instead.
I’m trying to use existing hardware instead of buying another ESP device.
1-1.2
Subsystem:
usb
Device path:
/dev/bus/usb/001/004
Attributes:
BUSNUM: '001'
DEVNAME: /dev/bus/usb/001/004
DEVNUM: '004'
DEVPATH: /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.1.auto/usb1/1-1/1-1.2
DEVTYPE: usb_device
DRIVER: usb
ID_BUS: usb
ID_FOR_SEAT: usb-platform-xhci-hcd_1_auto-usb-0_1_2
ID_MODEL: eHome_Infrared_Transceiver
ID_MODEL_ENC: eHome\x20Infrared\x20Transceiver
ID_MODEL_ID: '0815'
ID_PATH: platform-xhci-hcd.1.auto-usb-0:1.2
ID_PATH_TAG: platform-xhci-hcd_1_auto-usb-0_1_2
ID_REVISION: '0000'
ID_SERIAL: Philips_eHome_Infrared_Transceiver_PH00OyLA
ID_SERIAL_SHORT: PH00OyLA
ID_USB_INTERFACES: ':ffffff:'
ID_USB_MODEL: eHome_Infrared_Transceiver
ID_USB_MODEL_ENC: eHome\x20Infrared\x20Transceiver
ID_USB_MODEL_ID: '0815'
ID_USB_REVISION: '0000'
ID_USB_SERIAL: Philips_eHome_Infrared_Transceiver_PH00OyLA
ID_USB_SERIAL_SHORT: PH00OyLA
ID_USB_VENDOR: Philips
ID_USB_VENDOR_ENC: Philips
ID_USB_VENDOR_ID: '0471'
ID_VENDOR: Philips
ID_VENDOR_ENC: Philips
ID_VENDOR_ID: '0471'
MAJOR: '189'
MINOR: '3'
PRODUCT: 471/815/0
SUBSYSTEM: usb
TAGS: ':seat:'
TYPE: 0/0/0
USEC_INITIALIZED: '4090340'
My version information is below:
