IR Receiver, save aeha Address and Data in two different text_sensor
Hello, i would like to use the aeha code received publishing on text_sensor for address and another text sensor for data, so i can use immediately the code to test and avoid the modification in YAML.
this is just one example
remote_receiver:
  • pin:
    number: GPIO5
    inverted: true
    mode:
    input: true
    pullup: true
    dump: aeha
    on_aeha:
    then:
    • rtttl.play: ‘s:d=4,o=7,b=1000:32b4’
    • text_sensor.template.publish:
      state: !lambda ‘char buffer [30];return data(data.address,buffer,16);’
I tried to write a lot of lambda but i receive always errors when compiling.
