I try many config with 2 different receiver on ESP32
remote_receiver:
dump: all
tolerance: 50%
filter: 250us
idle: 4ms
pin:
number: GPIO32
inverted: True
I try GPIO04 16 17 23 32
I alway get a flood like this:
remote_receiver:
dump: all
tolerance: 50%
filter: 250us
idle: 4ms
pin:
number: GPIO32
inverted: True
could be sun light
I’m in the basement, all light are close and i place the receiver under a box.
ok, i found why, I just change the ground and that work now
I am having a very similar problem. I’ve tried several esp32 units, and different gpio ports, all leading to the same result.
I have also tried different tsop 38238 receivers.
At initial code load in Esphome, everything works fine.
However, after a bit of use, the remote button press is no longer a recognized command.
Here is a picture of what the log shows:
Any ideas?
Thanks!
I have found others are having the same issue:
