I installed esphome in a wemos d1 mini with the ir remote climate component.
All works fine except the model,
In documentation I read I must set the model to have the right min and max temparature:
whirlpool
Climate:
- model (Optional, string): There are two valid models to choose from:
DG11J1-3A
: Temperature range is from 18 to 32 (default)DG11J1-91
: Temperature range is from 16 to 30
I put it but the min max temperature is always default (18-30) can you help me?
remote_receiver:
pin:
number: D5
inverted: true
mode:
input: true
pullup: true
# high 55% tolerance is recommended for some remote control units
tolerance: 55%
remote_transmitter:
pin: D2
carrier_duty_percent: 50%
climate:
- platform: whirlpool
model: "DG11J1-91"
sensor: current_studio_temperature
receiver_id: rcvr
