I have 2 air conditioners in one room, I am using two same IR Remote Control, I am getting interference, how can i avoid that?
Thank you
Thank you
I have multiple AV equipment that I control through IR. I use global cache as a blaster.
Here is my Automation and script. If you don’t give time in between calls you end of with interference.
- id: 'Rack On-Off For Music'
alias: Rack On-off for Music
description: Boolean toggled from off to on. Run script to turn on music rack.
- id: 'on'
platform: state
entity_id: input_boolean.rackmusic
to: 'on'
- id: 'off'
platform: state
to: 'off'
condition: []
- choose:
- conditions: "{{ trigger.id == 'off' }}"
sequence:
- service: script.avrack_off
- conditions: "{{ trigger.id == 'on' }}"
sequence:
- service: script.avrack_on
default: []
mode: single
and here is the script
avrack_on:
alias: Rack On For Music
sequence:
- service: switch.turn_on
data: {}
entity_id:
- switch.media_room_rack_duplex
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 200
data: {}
entity_id: switch.comm_closet_amp_duplex
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 200
- service: remote.send_command
data_template:
entity_id: remote.nadz0
command: poweron
device: remote.nadz0
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 500
data_template:
command: input4video4
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 500
data_template:
entity_id: remote.nadz1
command: poweron
device: remote.nadz1
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 500
data_template:
entity_id: remote.denon
command: poweronallzones
device: remote.denon
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 500
- service: media_player.media_play
data: {}
entity_id: media_player.daphile_coax
mode: single
avrack_off:
alias: Rack Off For Music
sequence:
- service: media_player.media_stop
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 500
data_template:
command: poweroffallzones
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 750
data_template:
command: poweroff
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 750
data_template:
command: poweroff
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 750
- service: switch.turn_off
data: {}
entity_id:
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 500
data: {}
mode: single
icon: hass:music
avracktheater_on:
alias: Rack On For Theater
sequence:
data: {}
entity_id:
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 500
data: {}
entity_id: switch.media_room_vizio_tv
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 500
data_template:
command: poweron
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 750
data_template:
command: input1video1
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 750
data_template:
entity_id: remote.epson
command: poweron
device: remote.epson
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 750
data_template:
entity_id: remote.hdmi
command: gtvtomediaprojector
device: remote.hdmi
mode: single
I don’t have automation, just when I press the 1st remote will reflect on both remotes…
