With an IR reciever I’ve succesfully taken the raw codes from the remote of my electric fireplace. With the IR transmitter I can now turn of the fireplace, but I cannot turn it on. Though I cannot see in the codes why it wouldn’t work.
When you turn off the fireplace with the remote, the dispay on the remote also goes off. When you turn off the fireplace with HA, the display on the remote stays on. When you press the on/off button, the display on the remote will go off, but the fireplace will not turn on. So there is some kind of difference between an off and on command.
Here are the commands the remote sends when turning on and off:
Off:
[23:27:01][I][remote.raw:028]: Received Raw: 5558, -2487, 5502, -2478, 529, -479, 557, -509, 529, -481, 556, -479, 558, -480, 558, -1545, 531, -508, 528, -1545, 529, -1546, 529, -480, 557, -481, 557, -509, 528, -482, 555, -481, 556, -509, 530, -483, 553, -483, 554, -1545, 531, -1544,
[23:27:01][I][remote.raw:041]: 530, -1546, 530, -1544, 530, -1544, 530, -1546, 530, -1545, 530
On:
[23:27:07][I][remote.raw:028]: Received Raw: 5559, -2462, 5527, -2480, 529, -508, 528, -481, 556, -510, 528, -483, 555, -480, 556, -1546, 529, -479, 558, -1546, 529, -480, 557, -483, 554, -482, 556, -481, 555, -510, 529, -480, 556, -509, 529, -509, 532, -1542, 529, -1545, 531, -1546,
[23:27:07][I][remote.raw:041]: 530, -1543, 531, -1544, 530, -1546, 530, -1544, 530, -1546, 529
And here is my ESPhome:
remote_receiver:
pin:
number: GPIO5
inverted: True
dump: raw
remote_transmitter:
pin: GPIO4
# RF uses a 100% carrier signal
carrier_duty_percent: 50%
switch:
turn_off_action:
- remote_transmitter.transmit_raw:
carrier_frequency: 38kHz
code: [5559, -2487, 5504, -2480, 529, -482, 555, -482, 556, -483, 555, -509, 530, -479, 557, -1546, 530, -481, 556, -1547, 530, -1546, 535, -476, 556, -483, 555, -509, 529, -508, 529, -509, 529, -482, 556, -482, 556, -481, 556, -1545, 531, -1547, 530, -1544, 531, -1544, 531, -1547, 531, -1544, 531, -1545, 531]
turn_on_action:
code: [5556, -2486, 5502, -2480, 528, -482, 555, -484, 554, -481, 556, -481, 555, -489, 550, -1547, 529, -508, 528, -1545, 529, -1546, 530, -481, 556, -509, 529, -480, 557, -482, 556, -507, 529, -509, 530, -480, 556, -510, 528, -1545, 529, -1545, 530, -1546, 530, -1545, 529, -1545, 530, -1546, 529, -1545, 530]
I cannot see why the fireplace ignores the ‘on’ command. Does anyone know what the remote could be doing differently when turning on? And what I could try?
