Hi all,
since ESPHome 2025.11 i can no longer build ESPHome for a az-delivery-devkit-v4.
Erros says:
Successfully created ESP32 image.
Linking .pioenvs/bpvesp3201/firmware.elf
/data/cache/platformio/packages/toolchain-xtensa-esp-elf/bin/../lib/gcc/xtensa-esp-elf/14.2.0/../../../../xtensa-esp-elf/bin/ld: .pioenvs/bpvesp3201/firmware.elf section `.iram0.text' will not fit in region `iram0_0_seg'
/data/cache/platformio/packages/toolchain-xtensa-esp-elf/bin/../lib/gcc/xtensa-esp-elf/14.2.0/../../../../xtensa-esp-elf/bin/ld: IRAM0 segment data does not fit.
/data/cache/platformio/packages/toolchain-xtensa-esp-elf/bin/../lib/gcc/xtensa-esp-elf/14.2.0/../../../../xtensa-esp-elf/bin/ld: region `iram0_0_seg' overflowed by 348 bytes
collect2: error: ld returned 1 exit status
*** [.pioenvs/bpvesp3201/firmware.elf] Error 1
Last working version was ESPHome 2025.10.5, that I could successfully build and install.
Any clues on that? Tried taking out lots of functionality (shrink the image) but no efect at all - always states the same overflow byte amount.
Also ofc cleaned up the build files multiple times ![]()
Thanks and regards
Jakob
