I bought a lot of 10 of v1 Iris Zigbee motion sensors (MOT800) from an eBay seller. They’re small, can be mounted on a wall or ceiling and appear to be in pristine condition - and you can’t beat the price of discontinued Iris gear when adding to your Home Assistant setup.
That is, assuming they work.
I’m unable to pair them with my Nortek HUSBZB-1 on my RP4 running Hass.io. (For reference, when I began my Home Assistant journey a few weeks ago, all my Zigbee and Z-Wave devices have paired/included flawlessly.)
I’ve followed the only reset and pairing instructions that I could find on the Hubitat site. (No manual could be found.)
I can envision a few reasons why I can’t pair these devices:
- They’re not functioning properly or are non-standard.
- I didn’t properly reset them.
- The Zigbee library used by HA doesn’t support them.
- Probably a bunch of other reasons I’m failing to consider.
The output of the ZHA log when attempting to pair the device is below.
Does anyone have experience with these?
Can someone recommend some other things I can troubleshoot? I’d really like to get them working.
Thanks in advance.
ZHA Log
[0x0000:zdo] ZDO request 0x0036: [60, <Bool.false: 0>]
Device 0x4d4a (00:0d:6f:00:03:c2:23:16) joined the network
Device 00:0d:6f:00:03:c2:23:16 changed id (0x03ec => 0x4d4a)
Skip initialization for existing device 00:0d:6f:00:03:c2:23:16
[0x4d4a] Requesting 'Node Descriptor'
[0x4d4a] Extending timeout for 0x65 request
[0x4d4a] Delivery error for seq # 0x65, on endpoint id 0 cluster 0x0002: message send failure
[0x4d4a] Extending timeout for 0x67 request
[0x4d4a] Delivery error for seq # 0x61, on endpoint id 0 cluster 0x0005: message send failure
[0x4d4a] Extending timeout for 0x69 request
[0x4d4a] Delivery error for seq # 0x67, on endpoint id 0 cluster 0x0002: message send failure
[0x4d4a] Requesting Node Descriptor failed: [0x4d4a:0:0x0002]: Message send failure
[0x4d4a] Discovering endpoints
[0x4d4a] Extending timeout for 0x6b request
[0x4d4a] Delivery error for seq # 0x69, on endpoint id 0 cluster 0x0005: message send failure
Failed ZDO request during device initialization: [0x4d4a:0:0x0005]: Message send failure
[0x4d4a] Delivery error for seq # 0x6b, on endpoint id 0 cluster 0x0005: message send failure
[0x4d4a] Extending timeout for 0x6d request
[0x4d4a] Extending timeout for 0x6f request
[0x4d4a] Delivery error for seq # 0x6d, on endpoint id 0 cluster 0x0005: message send failure
[0x4d4a] Extending timeout for 0x71 request
[0x4d4a] Delivery error for seq # 0x6f, on endpoint id 0 cluster 0x0002: message send failure
[0x4d4a] Extending timeout for 0x73 request
[0x4d4a] Delivery error for seq # 0x71, on endpoint id 0 cluster 0x0005: message send failure
[0x4d4a] Delivery error for seq # 0x73, on endpoint id 0 cluster 0x0002: message send failure
[0x4d4a] Extending timeout for 0x75 request
[0x4d4a] Extending timeout for 0x77 request
[0x4d4a] Delivery error for seq # 0x75, on endpoint id 0 cluster 0x0005: message send failure
[0x4d4a] Delivery error for seq # 0x77, on endpoint id 0 cluster 0x0005: message send failure
[0x4d4a] Extending timeout for 0x79 request
[0x4d4a] Extending timeout for 0x7b request
[0x4d4a] Delivery error for seq # 0x79, on endpoint id 0 cluster 0x0005: message send failure
[0x4d4a] Delivery error for seq # 0x7b, on endpoint id 0 cluster 0x0005: message send failure
Device 0x8072 (00:0d:6f:00:03:c2:23:16) joined the network
Device 00:0d:6f:00:03:c2:23:16 changed id (0x4d4a => 0x8072)
Canceling old initialize call
[0x8072] Requesting 'Node Descriptor'
[0x8072] Extending timeout for 0x7d request
[0x8072] Extending timeout for 0x7f request
