I don’t see an entity or status that tells me if the vacuum is stuck? Am I missing that?
All I am not getting any logbook entries for this device yet all entities are reporting fine?
Thanks.
Thanks.
The roomba device status will change to stuck. Here’s my trigger for one of my vacuums getting stuck:
platform: state
entity_id:
- vacuum.roomba
attribute: status
to: Stuck
And when I want details, I just grab it from the error attribute (this is my own homemade TTS script, ignore the service and use your own):
service: shell_command.speak
text: >
{% set message = '' %} {% set error = state_attr('vacuum.roomba', 'error')
%} {% set message = message + "The vacuum is complaining, the
problem is: " + error %} {{ message }}
Thanks, to confirm this device will change to stuck? I am not getting anything in the logs as previously noted so difficult to tell what status changes it is going through.
Yes. You get more detail when you click the Roomba itself to get to the full controls of it, but yes, it will say Stuck or Error
Well, I see that there’s a need to extend the set of Roomba states that the integration exposes.
