Hi all,
I am trying to add the iRoboto integration to my ha instance.
I go to integrations and install the iRobot thing. It asks me for IP/ Hostname and the BLID. I have both and enter them here.
Then it asks me to press the “Home”-Button on my Roomba what I am doing. Shortly after I am getting “Connection refused” in the logfile:
2021-06-04 13:25:04 WARNING (roombapy) [roombapy.roomba] Unexpectedly disconnected from Roomba wischer.example.com, code Unable to connect to Roomba at wischer.example.com
2021-06-04 13:26:26 ERROR (roombapy) [roombapy.remote_client] Can't connect to 192.168.2.51, error: [Errno 111] Connection refused
2021-06-04 13:26:26 ERROR (roombapy) [roombapy.remote_client] Unable to connect to 192.168.2.51
2021-06-04 13:26:26 WARNING (roombapy) [roombapy.roomba] Unexpectedly disconnected from Roomba 192.168.2.51, code Unable to connect to Roomba at 192.168.2.51
Well, I have double checked settings and there is not firewall rule blocking anything in between the ha and the roomba. nmap
tells me, port 8883 is open. I even did a packet trace which discovered some SSL related error:
SSL::Invalid_Server_Cert
SSL certificate validation failed with (unable to get local issuer certificate)
CN=iRobot-5719918A4BCD4F54B116D7353D6E9D88,OU=Production,O=iRobot Corporation,L=Beford,ST=Massechusetts,C=US
Well, does not make sense to me. I bet it is an official certificate. But why is it not able to verify?
However, the installation then stops.
Can I install the integration manually and then edit the configuration file to match BLID and so on?
Note: I run the ha appliance and do not have console access.
Thanks for any ideas!
/KNEBB
