@Jeremy, is it me only or 0.110 broke your vacuum card - I do not see the background?
Also searching for background image (to rule out something wrong with this part) I noticed that integration creates images of cleaning map after each cleanup in vacuum directory. Should I take care about (I mean periodicaly clean the directory) or these are somehow discarded automatically after some time?
Yes, just need to effectively setup two instances, one for Roomba, one for braava.
Yeah it has - simple fix I’ll sort it out tomorrow morning !
Sorry for maybe a noob question, how and what do you mean by 2 instances?
In the config section in the add-on is that where I enter two of the same?
Ah, I’ll spin up a second instance on my repo in the morning so you have the option
Thanks a million!
I already did that Because i need second instance
I’ve added second instances this morning
background has been fixed in latest lovelace card release this morning
I have updated the GH Repo to include performing image cleanup
Review this commit for details
I am thinking to buy a robot vacuum, but I haven’t decided which brand. I saw irobot and xiaomi these two have been developed quite well with HA.
if your considering the roomba, i highly recommend getting the plus model (with clean base)
yes its more expensive, but not having to empty the bin is magical
Has anyone had an issue with the i7/i7+ where after establishing the integration in HA, it becomes unavailable? Is there a trick to keeping this alive?
Greg
which integration? this deployment does not use the built-in “vacuum” component?
@Syrius maybe is already answered but I can’t find it. Is it possible that somehow data for last cleaning job are visible directly from sensor.rest980 (for my Roomba 980 model) like in iRobot app on the phone - duration, cleaning area - something like in picture below:
these, for the most part should already be exposed as job attributes under sensor.vacuum ?
On my side exposed are total (overall) values not the data for the last job. I’m speaking for my iRobot 980 model. I don’t know if there is some other data for newer models like i7…
Below is my screenshot for this sensor.vacuum:
Check the GH Repo, there’s been a few updates since then!
The Roomba integration.
if your using the native roomba integration, then I’m not sure as i don’t use it. Using rest980 (the configuration represented in this thread) is a replacement for that.
