IronOS: Soldering Fume Extractor Automation (Pinecil V2)
Automatically activate the fume extractor when soldering begins and deactivate it when the soldering iron is idle.
blueprint:
  name: "IronOS: Soldering Fume Extractor Automation"
  description: "Automatically activate the fume extractor when soldering begins and deactivate it when the soldering iron is idle."
  author: tr4nt0r
  homeassistant:
    min_version: 2024.8.0
  domain: automation
  input:
    operating_mode:
      name: "Operating Mode Sensor"
      description: Select the operating mode sensor of your IronOS device. The automation will turn on the fume extractor when the mode switches to 'soldering' and turn it off when the mode changes from 'soldering' to 'idle'."
      selector:
        entity:
          filter:
            - domain: sensor
              integration: iron_os
              device_class:
                - enum
    fume_extractor:
      name: "Fume Extractor Control Switch"
      description: "Select the switch used to control the on/off state of your fume extractor."
      selector:
        entity:
          filter:
            - domain: switch
triggers:
  - trigger: state
    entity_id: !input operating_mode
    to: soldering
    id: start soldering
  - trigger: state
    to: idle
    id: stop soldering
conditions: []
actions:
  - if:
      - condition: trigger
        id:
          - start soldering
    then:
      - action: switch.turn_on
        metadata: {}
        data: {}
          entity_id: !input fume_extractor
  - if:
        id:
          - stop soldering
    then:
      - action: switch.turn_off
        metadata: {}
        data: {}
mode: single
