there we go!
I started at type:
I omitted the second - entity: line
Thanx Pete!!
there we go!
I started at type:
Thanx Pete!!
Hi Peter!
Finally had some time to upgrade from v2 to v3. Seems to work great! I haven’t dug into all the new features such as the reduction of irrigation time, etc. But I did notice one thing I wanted to double check – With the new setup, you have the solenoids broken out directly, not the zones like it used to be. That allows you to enable more than one zone at a time (manually), and when you enable a zone, it doesn’t act like it used to in v2 (it would just run that zone for the configured time and it would shut off automatically). It’s not a problem for me, but I wanted to double check that that was by design and not a result of something I messed up in the shift from v2 to v3 …
Thanks again for your awesome work!
Hi Robbert,
You are right, now the zones are integrated into each program, the only way to run an individual zone is to start the switch that is linked to your solenoid. I personally only have the solenoids visible as part of the test harness to make sure that they have actually started.
I’m much happier with this version, I can’t think of any other features to add, so now I am looking for my next project.
I have created a companion component to collect 5 days of history using the openweathermap API and calculate an adjustment factor that can be used in the Irrigation component.
A home assistant sensor that uses the OpenWeatherMap API to get the last 5 days rainfall. A call is made for each day so the scan_interval is set at 3600 seconds (1 hour) as the free tier allows only 1000 calls per day.
This information is used to calculate a factor that can be used to reduce the watering time of the Irrigation Program custom component.
A OpenWeatherMap API Key is required see the OpenWeatherMap custom component for more information.
You need an API key, which is free, but requires a registration.
The adjustment factor is calculated based on the the cumulative rainfall for each day. For yesterday the cumulative value is today’s (day 0) rainfall + yesterday’s (day 1) rainfall.
The lowest factor of the up to five days of rainfall is return as the state of the sensor.
factor = 1 - ((cumulative rainfall - daymin)/(daymax - daymin))
If the factor is less than 0 the factor is set to 0.
Attributes are returned for:
This is the first iteration of this and any feedback is appreciated.
oops wrong component
oops, wrong component
New Version 3.0.3 release with minor bug fix enhancements.
Version 4 of the custom component is now available. This release comes with some new options and support for a new custom card.
Custom Card
I am not the best UI developer so this utilises the entities card model to present the objects defined for the custom component. This is my first custom card so feedback and assistance will be welcomed.
Breaking Change
There is a minor breaking change for anyone using the run_days option in version 3. Please rename run_days to run_freq to maintain the existing capability. As the capabilities have been merged into a single option.
Please review the documentation in the GITHUB repository for all changes.
Summary of Changes
This is a new release, despite my best efforts there is going to be an issue or two, if you find issues please log them in the GITHUB issues for the respective archives or let me know in this forum.
If you use the component let me know, I would love to know if and where it is being used.
V1.0.1 of the Custom Card for Irrigation component released with improved error handling.
hi petergridge
thanks a lot for your component, i’m probably not the only one to migrate the old rainbird controller to ha. , i’m suprised that this component is not more popular.
i have installed all your component ( irrigation V4, custom card , and openweathremaphistory ) i have a nice dashboard, but i’m struggling to understand how to set up the automation to fit my need. and to have it active
i would like to run on sprinkler every 2 days for a duration X , which will be adjusted by sensor.rainfactor (set by openweathremaphistory ).
i’m probably missing the last configuration step , could you point me the direction ?
Hi Froggy,
Can you send me a copy of your config, I will look at it and get back to you.
Cheers
Pete
thanks petergridge
i’m not sure to understand which config file i need to send to you
at this stage, i have only installed all the custom component and the irrigationtest.yaml package.
i’m trying to understand what config i need to modify in order to make the automation run
Hi
Thank you for your great work.
In v4 when I set water time more then 6 min its display 1:06.59, if more then 12 min its 2:12:59 and etc.
Also when you run program and stop it adjust any parameter or not and run again, the timer not correctly countdown.
And water adjustment must be more then 0 to be run program?
Thank you.
I have corrected the calculation for the remaining time.
The watering adjustment is designed to be a factor 0 if you detect that it is raining and no watering is required to 1 if it has been dry and you need a full watering cycle. As a result it is zero the zone/s it is associated with will not run.
Cheers
Pete
Hi Froggy,
Try this:
Use the yaml below to replace irrigationtest.yaml and change line 24 zone: switch.dummy_1 to switch.yourswitch, the switch exposed to HA by your irrigation controller.
input_datetime:
irrigation_afternoon_start_time:
name: Afternoon Start Time
has_date: false
has_time: true
- platform: time_date
display_options:
- 'time'
- 'date'
- platform: openweathermaphistory
api_key: !secret openweatherapi
switch:
- platform: irrigationprogram
switches:
afternoon:
start_time: input_datetime.irrigation_afternoon_start_time
run_freq: input_select.irrigation_freq
zones:
- zone: switch.dummy_1
water: input_number.irrigation_lawn_run
icon: mdi:grass
switches:
dummy_1:
value_template: "{{ is_state('input_boolean.dummy_switch_1', 'on') }}"
turn_on:
entity_id: input_boolean.dummy_switch_1
turn_off:
- service: input_boolean.turn_off
input_number:
irrigation_lawn_run:
min: 1
max: 30
step: 1
icon: mdi:water
input_select:
# Use either run days of Frequency they are mutually exclusive
irrigation_freq:
options:
- "1"
- "2"
- "3"
- "4"
- "5"
- "6"
- "7"
input_boolean:
irrigation_on:
name: Enable Irrigation
dummy_switch_1:
I have also identified an issue with the implementation of the watering adjustment that I will work and and release a new version shortly. Currently it does not support the provision of a sensor just input_number.
I hope this helps, let me know how you go.
Cheers
Thanks for the feedback:
Updated versions now available of both the custom component and custom card.
thanks a lot peterridge.
it works perfectly
in your yaml , i don’t see how the duration is adjusted by the rain factor from openweather.
how can i check this ?
I did not have the water adjustment configured in the sample above was just keeping it simple. See the update below. If it has not been raining where you are you can change the location on the sensor to somewhere you know it is (it’s pouring in Sydney Aus today) and test against other locations. See the rain history page for the latitude and longitude settings.
You can also write your own template sensor to use the attributes of the openweatherhist to do your own calculation or use any other inputs.
Cheers
Pete
Hi Pete
input_datetime:
irrigation_morning_start_time:
name: Morning Start Time
has_date: false
has_time: true
has_date: false
has_time: true
irrigation_night_start_time:
name: Night Start Time
has_date: false
has_time: true
display_options:
- 'time'
- 'date'
# - platform: openweathermaphistory
# name: 'rainfactor'
# api_key: !secret openweatherapi
switch:
switches:
morning:
irrigation_on: input_boolean.irrigation_on
start_time: input_datetime.irrigation_morning_start_time
#will run only on selected run days
run_freq: input_select.irrigation_run_days
icon: mdi:fountain
zones:
- zone: switch.relay1
# no rain sensor will alway run
water: input_number.irrigation_zone_1_run
rain_sensor: binary_sensor.raining
ignore_rain_sensor: input_boolean.irrigation_ignore_rain_sensor
water_adjustment: input_number.irrigation_adjust_run
icon: mdi:grass
- zone: switch.relay2
# rain sensor with ignore option
#irrigation_on: input_boolean.irrigation_on
water: input_number.irrigation_zone_2_run
#wait: input_number.irrigation_pot_plants_wait
#repeat: input_number.irrigation_pot_plants_repeat
icon: mdi:grass
- zone: switch.relay3
water: input_number.irrigation_zone_3_run
icon: mdi:grass
afternoon:
icon: mdi:fountain
zones:
#rain_sensor: binary_sensor.raining
#ignore_rain_sensor: input_boolean.irrigation_ignore_rain_sensor
#water_adjustment: input_number.irrigation_adjust_run
icon: mdi:grass
icon: mdi:grass
icon: mdi:grass
- zone: switch.relay4
water: input_number.irrigation_zone_4_run
#run_freq: input_select.irrigation_run_days
icon: mdi:flowe
switches:
dummy_1:
turn_on:
turn_off:
dummy_2:
value_template: "{{ is_state('input_boolean.dummy_switch_2', 'on') }}"
turn_on:
entity_id: input_boolean.dummy_switch_2
turn_off:
dummy_3:
value_template: "{{ is_state('input_boolean.dummy_switch_3', 'on') }}"
turn_on:
entity_id: input_boolean.dummy_switch_3
turn_off:
dummy_4:
value_template: "{{ is_state('input_boolean.dummy_switch_4', 'on') }}"
turn_on:
entity_id: input_boolean.dummy_switch_4
turn_off:
input_number:
irrigation_adjust_run:
name: water adjustment
min: 0
max: 1
step: 0.2
icon: mdi:water-pump-off
irrigation_pot_plants_run:
min: 1
max: 30
step: 1
icon: mdi:water
irrigation_pot_plants_wait:
min: 0
max: 10
step: 1
icon: mdi:timer-sand
irrigation_pot_plants_repeat:
min: 1
max: 10
step: 1
icon: mdi:repeat
irrigation_zone_1_run:
min: 1
max: 30
step: 1
icon: mdi:water
irrigation_zone_2_run:
min: 1
max: 30
step: 1
icon: mdi:water
irrigation_zone_3_run:
min: 1
max: 30
step: 1
icon: mdi:water
irrigation_zone_4_run:
min: 1
max: 30
step: 1
icon: mdi:water
input_select:
irrigation_run_days:
options:
- "['Wed','Sat']"
- "['Sun','Thu']"
- "['Mon','Fri']"
- "['Tue','Sat']"
- "['Sun','Wed']"
- "['Mon','Thu']"
- "['Tue','Fri']"
- "['Mon','Wed','Fri']"
- "['Mon','Tue','Wed','Thu','Fri','Sat','Sun']"
irrigation_freq:
options:
- "1"
- "2"
- "3"
- "4"
- "5"
- "6"
- "7"
input_boolean:
irrigation_on:
irrigation_config:
name: Show Configuration
irrigation_ignore_rain_sensor:
name: Ignore Rain Sensor
dummy_switch_1:
dummy_switch_2:
dummy_switch_3:
dummy_switch_4:
dummy_rain_sensor:
binary_sensor:
sensors:
raining:
device_class: moisture
value_template: "{{ is_state('input_boolean.dummy_rain_sensor', 'on') }}"
icon_template: >-
{% if is_state("binary_sensor.raining", "on") %}
mdi:weather-pouring
{% else %}
mdi:weather-sunny
{% endif %}
this is my config , when I try to add morning and afternoon programs I have this error.
A silly error on my part, I have added this scenario to my testing as well. I have uploaded a new version 4.0.3.
I am currently working on some cleaning up of v4 to reduce the amount of redundant code that has crept in so keep an eye out for version 4.1.0 in the next week or two.
If you have any feature requests I am feeling motivated at the moment.
Cheers
