Irrigation Hunter X-Core remote control using REM pin
Well the project is mostly done. Everything’s breadboarded and tested on my bench X-Core 400. What’s left is to try this on my real irrigation controller outside, finish a PC board layout and finalize the power supply. (I’m running awfully close to the limits on the DC-DC converter and I want some more protection.)
I’ve uploaded much of the project to Github at GitHub - czsmith/HunterMonitor: ESPHome project to monitor Hunter X-Core 400 irrigation controllers and allow remote operation. The README includes a lot more information about the implementation. Included are the schematics and ESPHome yaml file.
Here’s the current circuit schematic:
and a screenshot of the local UI
I want to thank everyone here for the information provided, and to Javier VIdao for providing a working ESPHome component to send commands to the Hunter X-Core on the ROAM interface.
In the next week or two, I’ll be finishing a PCB design. That’ll be the only way to fit everything on a 2x2.5 inch board to fit inside the Hunter unit.
Again, Thanks to everyone.
(And if anyone needs crediting, just let me know & I’ll update the README file on Github.)
Amazing job Chris @czsmith , I have implemented it on a Wemos D1 Mini Pro I had and today I connected the protoboard to test and it just works !!.
I used a TLP620-4 for the inputs and PC817 for the outputs. Now I will put everything in a small board and fit it inside XCORE definitely
As my garden is using only 3 zones right now, I will block the use of zone 4 inside code to avoid big fingers starting the submersible pump without any open valve.
As my system has installed the Hunter rain sensor, you need to connect the optocoupler output in series with the sensor to work because the SEN input is waiting a NC contact to allow XCORE works.
Glad it worked out.
I also have only 3 sensors on my own house. Since I’m in an HOA, I don’t decide if the pump is on or nor. So, I keep looking for some way to determine if there is really pressure in the main lines. (without having to drill a hold into them… they’re not mine) and use the 4th input to tell if I am actually watering my yard. Maybe some type of vibration sensor?
In your case you could use the 4th input to sense the rain sensor line. Would let you know if you are really watering or not.
Hi there, I have wired up my Wemos D1 mini like @wrongisthenewright, and flashed their firmware, but is it wise to wire it that way? Thanks
In my case it’s 2 years that is running fine without any complaint from Hunter device. I have to admit that after installing a new “brain” the hunter itself it’s always set to the OFF settings, al lthe scheduling etc is done on opensprinkler
oops… the wires are backwards on U2. Pin 5 (collector) goes to VAC-24R and pin 4 (emitter) goes to REM. So sorry about that. Have to cut a couple traces on my pc boards. ;(
Hi! Have you finished your PCB design? I would be very interested
Thanks mate
Hello everyone. I have recently become interested in the irrigation system. Hunter is for sale in my country. I looked at a lot of reviews on the internet and found out that it doesn’t have any ready-made solutions for communication. I have been following this topic since the very beginning. What I don’t like about the Hunter is that for that kind of money it still remains a dumb garden waterer.
Can you tell me the main advantages of this controller? Well, except for the fact that after purchasing I will still have to make a separate ESP for control.
Спойлер
Hello guys.
I took the opportunity to use the work from czsmith above and developed my own PCB and it works!
If you are interested in more info about that please check https://github.com/luisfosoares/Hunter_LS/
Hi, so i spent the last day trying to implement my Hunter Pro-C via espHome. As I wanted a simple solution I went for only start/stop. Sadly I can only get the individual zones to start for the defined time, it can not be stopped. I also tryed sending 0 time but that wouldn’t work.
I wired it up as described here with a split usb cord
Maybe somebody can point me in the right direction what else I could try.
Luis,
That’s a beautiful looking board. And I like the way you managed to fit everything in the internal version of the X-Core. Having the external version, I have a different space to work with. Fortunately there’s enough room to mount the ESP board a bit off the main board so I can get a USB cable in there.
(Sadly, I’d ordered the PC board before I found that I’d gotten two wires backwards for driving the REM pin, so there’re two cut traces and wires on the bottom of my board.)
But it works just fine.
I’m glad you were able to use this work.
Thank you very much for your work, This is what I got so far. I also did a mistake with wiring (in my case for DC-DC converter). The board works like a charm :slight_smile:
Hello guys,
I have updated the board from v1.0.0 to 1.1.0 with new improved DC-DC converter and other small improvements and corrections
Feel free to check my GitHub and contact me if interested
Again, a nice engineering job. I was lucky to have the external model X-Core which leaves a large square space on the bottom.
The one thing I’m still searching for is a good way to determine if the main irrigation line is pressurized without having open tap the line itself. (The main is community-owned; just downstream from the valves are mine.) Something that can be placed on/around the main line and can detect static pressure, not just flowing water.
I have a hunter x-core 4 zones, and a lolin D1 mini pro (powered by usb)
Followed this thread and the links, written ecodina’s built firmware, setup the wifi / mqtt, rest endpoint works, then went to wire it up.
First wired 1’st 24VAC and REM to board’s GND and gipo16 , got ERR on the hunter
Then wired 2’nd 24 VAC and REM to the board’s GND and gipo16 , got no error, but also no action from the hunter.
Then split the USB charger cable, got 5v separately and took it to 1’st 24VAC, gipo16 to REM , got ERR on the hunter
another try with the split USB , but on 2’nd 24VACC, got me nothing again.
Later Edit:
Got it to work using 3v off the board directly
Small new update on the board, v1.1.1 with trace improvements
If any doubt or interest please check https://github.com/luisfosoares/Hunter_LS/tree/main
Hi is there a way to get/order a finished board alog with cables? My soldering skill sucks...
Maybe i can help you, check my email in the link
After being challanged i decided to upgrade the board to version 2.0.0 with up to 8 valves and a nicer/better controller.
This required full code review and some craft to avoid to change board size.
Nice job!
And going to a mini ESP32 is so smart… lots more GPIOs (get rid of the analog input) and in a smaller footprint!
Guess your next iteration is to smt or use some resistor arrays to save more space! (My eyesight and dexterity don’t allow me to work with that stuff.)
