Irrigation - Time Pattern/Schedule
Hi there!
How can I program a scheduled pattern of on/off cylces?
I need to water my greenhouse manually about once a month to clean out an excess of salt in soil (rest of the time is scheduled/automatic).
The automation should look like that: Trigger (Manual/ virtual switch) —> 10 minutes on (watering) —> 20 minutes off (pause) —> 10 minutes on (watering) —> 20 minutes off (pause) —> 10 minutes on (watering) —> 20 minutes off (pause).
I really tried to find something myself, but did not find a solution.
Can somebody give me a hint how to solve this?
Thank You!
Best regards,
Felix
Does this pattern continues for more hours or just that?
I use brute force and stupidity method.
- id: '1625852459827'
  alias: Water Lawn with timing given in frontend
  description: Water All 11 irrigation zones based on the times set in the front end
  - platform: time
    at: 04:00:00
  - platform: time
    at: 05:00:00
  - platform: time
    at: 06:00:00
  - platform: time
    at: '20:00:00'
  - platform: time
    at: '21:00:00'
  condition:
  - condition: state
    entity_id: sensor.watering_days
    state: '0'
  - type: turn_on
    device_id: 38223fea48e33bd0c222d08f40769e3e
    entity_id: switch.zone_1
    domain: switch
  - delay: '{{ states(''input_number.zone1'') | multiply(60) | int }}'
  - type: turn_off
    domain: switch
  - type: turn_on
    entity_id: switch.zone_2
    domain: switch
  - delay: '{{ states(''input_number.zone2'') | multiply(60) | int }}'
  - type: turn_off
    domain: switch
  - type: turn_on
    entity_id: switch.zone_3
    domain: switch
  - delay: '{{ states(''input_number.zone3'') | multiply(60) | int }}'
  - type: turn_off
    domain: switch
  - type: turn_on
    entity_id: switch.zone_4
    domain: switch
  - delay: '{{ states(''input_number.zone4'') | multiply(60) | int }}'
  - type: turn_off
    domain: switch
  - type: turn_on
    entity_id: switch.zone_5
    domain: switch
  - delay: '{{ states(''input_number.zone5'') | multiply(60) | int }}'
  - type: turn_off
    domain: switch
  - type: turn_on
    entity_id: switch.zone_6
    domain: switch
  - delay: '{{ states(''input_number.zone6'') | multiply(60) | int }}'
  - type: turn_off
    domain: switch
  - type: turn_on
    entity_id: switch.zone_7
    domain: switch
  - delay: '{{ states(''input_number.zone7'') | multiply(60) | int }}'
  - type: turn_off
    domain: switch
  - type: turn_on
    entity_id: switch.zone_8
    domain: switch
  - delay: '{{ states(''input_number.zone8'') | multiply(60) | int }}'
  - type: turn_off
    domain: switch
  - type: turn_on
    entity_id: switch.zone_9
    domain: switch
  - delay: '{{ states(''input_number.zone9'') | multiply(60) | int }}'
  - type: turn_off
    domain: switch
  - type: turn_on
    entity_id: switch.zone_10
    domain: switch
  - delay: '{{ states(''input_number.zone10'') | multiply(60) | int }}'
  - type: turn_off
    domain: switch
  - type: turn_on
    entity_id: switch.zone_11
    domain: switch
  - delay: '{{ states(''input_number.zone11'') | multiply(60) | int }}'
  - type: turn_off
    domain: switch
  mode: single
The key is the delay. I use an input time because it is watering my lawn but the concept is the same. The delay can cause problems if the system reboots during the automation.
Edit: I should note that I use garbage collection from HACS to set the watering day. This is an easy integration to setup and it works for lots of things.
Here is the cleaned setup from my configuration.yaml
# Use garbage collection to set events and holidays
garbage_collection:
  sensors:
  - name: Clean day
    frequency: even-weeks
    collection_days: thu
  - name: birthday
    frequency: annual
    date: '01/20'
  - name: birthday1
    frequency: annual
    date: '01/20'
  - name: birthday2
    frequency: annual
    date: '01/20'
  - name: Anniversary
    frequency: annual
    date: '01/20'
  - name: birthday4
    frequency: annual
    date: '01/20'
  - name: New Years Day
    frequency: annual
    date: '01/01'
  - name: Valentines
    frequency: annual
    date: '02/14'
  - name: Presidents Day
    frequency: "monthly"
    collection_days: "mon"
    weekday_order_number: 3
    period: 12
    first_month: "feb"
    last_month: "feb"
  - name: Memorial Day
    weekday_order_number: 5
    period: 12
    first_month: "may"
    last_month: "may"
  - name: Juneteenth
    frequency: annual
    date: '06/19'
  - name: Independence Day
    frequency: annual
    date: '07/04'
  - name: Labor Day
    weekday_order_number: 1
    period: 12
    first_month: "sep"
    last_month: "sep"
  - name: Halloween
    frequency: annual
    date: '10/31'
  - name: DiadelosAngelitos
    frequency: annual
    date: '11/01'
  - name: DíadelosDifuntos
    frequency: annual
    date: '11/02'
  - name: DíadelosMuertos
    frequency: annual
    date: '11/02'
  - name: Veterans Day
    frequency: annual
    date: '11/11'
  - name: Thanksgiving
    collection_days: "thu"
    weekday_order_number: 4
    period: 12
    first_month: "nov"
    last_month: "nov"
  - name: Christmas
    frequency: annual
    date: '12/25'
  - name: Boxing Day
    frequency: annual
    date: '12/26'
  - name: Watering Days #summer months
    frequency: "weekly"
    collection_days:
    - tue
    - thu
    - sun
    first_month: "apr"
    last_month: "oct"
This is a script that repeats the desired sequence of on/off commands 3 times:
alias: Sprinkler
sequence:
  - repeat:
      count: '3'
      sequence:
        - service: switch.turn_on
            entity_id: switch.sprinkler
        - delay: '00:10:00'
        - service: switch.turn_off
        - delay: '00:20:00'
mode: single
For convenience, create a Button Card with a tap_action to execute the script.
If you want to make an automation of it, use a State Trigger with an input_boolean.
alias: sprinkler Control
  - platform: state
    entity_id: input_boolean.sprinkler_flush
    to: 'on'
  - repeat:
      count: '3'
      sequence:
        - delay: '00:10:00'
        - delay: '00:20:00'
  - service: input_boolean.turn_off
mode: single
An enhanced version would include the ability to stop the repetitions if the input_boolean is manually turned off.
If you’re interested, your automation can also use repeat to perform the 11 repetitions.
  - platform: time
    at:
    - '04:00:00'
    - '05:00:00'
    - '06:00:00'
    - '20:00:00'
    - '21:00:00'
  condition:
  - condition: state
    state: '0'
  - repeat:
      count: 11
      sequence:
      - variables:
          zone: "switch.zone_{{ repeat.index }}"
          entity_id: '{{ zone }}'
      - delay:
          minutes: "{{ states('input_number.zone' ~ repeat.index) | int }}"
Thank you for the solution. Still learning and using the UI to get things up and running.
THANK YOU SO MUCH :grinning: :grinning: :grinning:
Especially Taras Solution is absolutely perfect!
Great community!
Thank You!
