I used to use AppDaemon for my automations, I am now moving to the HA automations.yaml
file and pyscript
for more complicated ones.
I created a simple automation via the GUI that works:
- id: '1606735537497'
alias: volets parents - soir
description: ''
- platform: sun
event: sunset
condition: []
- device_id: 2123c7d6fb4b11ea8642fdb20834c692
domain: cover
entity_id: cover.parents_volets
type: set_position
position: 10
mode: single
Since I have a few similar ones, I copied/pasted the above in automations.yaml
and I changed
- the
id
- the
description
and removed device_id
as I thought it was redundant with the entity_id
- id: '1606735537498'
alias: volets michael - soir
description: ''
- platform: sun
event: sunset
condition: []
- entity_id: cover.parents_volets
type: set_position
position: 10
mode: single
Apparently, I was wrong as I now get an error message in my automations:
2020-11-30 12:34:34 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: [type] is an invalid option for [automation]. Check: automation->action->0->type. (See /config/configuration.yaml, line 27).
The message suggests that there is a problem with type
but when i just removed device_id
the problem was with domain
(see the working version). So it looks like it is actually the lack of device_id
that triggers the issue.
Do I really need device_id
? If so I am not sure where to find it?
Otherwise, I will go for the GUI, even if it means clicking the same thing a few times.
