I’m trying to set up a sensor for my filament cabinet with an esp8266 and a bme280. I have this written to display the temp and humidity on the built in display of the esp device, and that works, yet I cannot get the sensor communicating along with the display. Here is what I am using
# Captive Portal configuration
captive_portal:
# I2C configuration
i2c:
display_sda: GPIO12 # SDA pin connected to GPIO12 for the SSD1306 display
display_scl: GPIO14 # SCL pin connected to GPIO14 for the SSD1306 display
sensor_sda: GPIO4 # SDA pin connected to GPIO4 for the BME280 sensor
sensor_scl: GPIO5 # SCL pin connected to GPIO5 for the BME280 sensor
scan: false
# Sensor configuration
- platform: bme280_i2c
temperature:
name: "Filament Cabinet Temperature"
humidity:
name: "Filament Cabinet Humidity"
pressure:
name: "Filament Cabinet Pressure"
address: 0x77 # Address of the BME280 sensor
update_interval: 60s
# Define a template sensor to convert Celsius to Fahrenheit
name: "Filament Cabinet Temperature (F)"
unit_of_measurement: '°F'
accuracy_decimals: 1
update_interval: 20s
lambda: |-
return id(bme_temperature).state * 9.0 / 5.0 + 32.0;
# Font configuration
font:
- file: 'slkscr.ttf'
- file: 'BebasNeue-Regular.ttf'
- file: 'arial.ttf'
# Display configuration
display:
- platform: ssd1306_i2c
model: "SSD1306 128x64"
reset_pin: GPIO16
address: 0x3C # Address of the SSD1306 display
lambda: |-
// Print temperature label
it.printf(0, 0, id(font1), TextAlign::TOP_LEFT, "Temp");
// Print temperature value directly
it.printf(0, 23, id(font3), TextAlign::TOP_LEFT, "%.1f°F", id(bme_temperature_fahrenheit).state);
// Print humidity label
it.printf(64, 0, id(font1), TextAlign::TOP_LEFT, "Humidity");
// Print humidity value directly
it.printf(64, 23, id(font3), TextAlign::TOP_LEFT, "%.1f%%", id(bme_humidity).state);
Thank you, it compiles fine, I believe the issue is that I’m not properly specifying the i2c pins for the bme AND the display. I can get one or the other working, but not both of them together.
[11:34:45][C][i2c.arduino:071]: I2C Bus:
[11:34:45][C][i2c.arduino:072]: SDA Pin: GPIO4
[11:34:45][C][i2c.arduino:073]: SCL Pin: GPIO5
[11:34:45][C][i2c.arduino:074]: Frequency: 50000 Hz
[11:34:45][C][i2c.arduino:086]: Recovery: bus successfully recovered
[11:34:45][C][bme280_i2c.sensor:025]: Address: 0x76
[11:34:45][C][bme280.sensor:182]: BME280:
[11:34:45][C][bme280.sensor:194]: IIR Filter: OFF
[11:34:45][C][bme280.sensor:195]: Update Interval: 60.0s
[11:34:45][C][bme280.sensor:197]: Temperature 'Filament Cabinet Temperature'
[11:34:45][C][bme280.sensor:197]: Device Class: 'temperature'
[11:34:45][C][bme280.sensor:197]: State Class: 'measurement'
[11:34:45][C][bme280.sensor:197]: Unit of Measurement: '°C'
[11:34:45][C][bme280.sensor:197]: Accuracy Decimals: 1
[11:34:45][C][bme280.sensor:198]: Oversampling: 16x
[11:34:45][C][bme280.sensor:199]: Pressure 'Filament Cabinet Pressure'
[11:34:45][C][bme280.sensor:199]: Device Class: 'pressure'
[11:34:45][C][bme280.sensor:199]: State Class: 'measurement'
[11:34:45][C][bme280.sensor:199]: Unit of Measurement: 'hPa'
[11:34:45][C][bme280.sensor:199]: Accuracy Decimals: 1
[11:34:45][C][bme280.sensor:200]: Oversampling: 16x
[11:34:45][C][bme280.sensor:201]: Humidity 'Filament Cabinet Humidity'
[11:34:45][C][bme280.sensor:201]: Device Class: 'humidity'
[11:34:45][C][bme280.sensor:201]: State Class: 'measurement'
[11:34:45][C][bme280.sensor:201]: Unit of Measurement: '%'
[11:34:45][C][bme280.sensor:201]: Accuracy Decimals: 1
[11:34:45][C][bme280.sensor:202]: Oversampling: 16x
[11:34:45][C][ssd1306_i2c:023]: I2C SSD1306
[11:34:45][C][ssd1306_i2c:023]: Rotations: 0 °
[11:34:45][C][ssd1306_i2c:023]: Dimensions: 128px x 64px
[11:34:45][C][ssd1306_i2c:024]: Address: 0x3C
[11:34:45][C][ssd1306_i2c:025]: Model: SSD1306 128x64
[11:34:45][C][ssd1306_i2c:026]: Reset Pin: GPIO16
[11:34:45][C][ssd1306_i2c:027]: External VCC: NO
[11:34:45][C][ssd1306_i2c:028]: Flip X: YES
[11:34:45][C][ssd1306_i2c:029]: Flip Y: YES
[11:34:45][C][ssd1306_i2c:030]: Offset X: 0
[11:34:45][C][ssd1306_i2c:031]: Offset Y: 0
[11:34:45][C][ssd1306_i2c:032]: Inverted Color: NO
[11:34:45][C][ssd1306_i2c:033]: Update Interval: 1.0s
[11:34:45][E][ssd1306_i2c:036]: Communication with SSD1306 failed!
[11:34:45][E][component:082]: Component display is marked FAILED
