So I just set up Tuya integration and what I experienced that was really weird was that the buttons and status was failing. Even if the logs said everything was a success.
What turned out to be the problem was that after following this: Tuya - Home Assistant, i had tried out different data centers to find my devices, and it turns out that things got screwed up when having multiple data centers in the config. I had two, and status and everything was weird. So I removed the data center that was wrong and set up the intergration again, then suddenly I could get the right status and turn on and off he lights again.
Hope this helps anyone
