Am I alone seeing empty pages at hass.config API docs?
Nope. Seems to have broken a while ago.
I will take a look. The local build works for me.
If you need the API docs then you could create them locally:
$ make html
See requirements_docs.txt
for the dependencies.
Any word on this? I still get no documentation. E.g., https://dev-docs.home-assistant.io/en/master/api/core.html#homeassistant.core.StateMachine, except for the boiler plate stuff and index on the left, is basically empty. Same for most, if not all, backend doc pages.
Nope, still on my todo list.
