daniel_d
(Daniel D.)
July 4, 2021, 7:18am
1
Hello all,
Since about 24 hours ago I (and Google Assistant) cannot access my Home Assistant installation via the Duck DNS domain.
I’ve done the following to troubleshoot the issue:
restarted router, modem and Raspberry Pi
rechecked the port forwarding
rechecked the DMZ settings on the modem
tried to access HA via the local name - works
tried to access HA via the external IP - works
deleted and recreated the Duck DNS domain
added a secondary domain on Duck DNS - works
Now I am scratching my head trying to figure out what the heck is happening. But I am 99% sure that there is something working with the DNS service. I haven’t changed anything on HA in the last days and Duck DNS was untouched since about 3 months ago.
Is anybody else having a similar problem?
Thanks!
tom_l
July 4, 2021, 7:41am
2
On the duckDNS web admin page, does it report the correct public IP for your router?
daniel_d
(Daniel D.)
July 4, 2021, 7:55am
3
Sorry for forgetting to mention…
Yes, the reported IP is correct and it seems to be propagated to all majod DNS backbones.
tom_l
July 4, 2021, 9:23am
5
Are your security certificates valid?
Is your system clock time correct?
daniel_d
(Daniel D.)
July 4, 2021, 11:25am
6
It looks like I have a problem with the certificate renewal…
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] done.
[services.d] starting services
[services.d] done.
# INFO: Using main config file /data/workdir/config
+ Account already registered!
[13:10:17] INFO: OK
88.0.67.xx
NOCHANGE
[13:10:17] INFO: Renew certificate for domains: xxxx1.duckdns.org and aliases:
Processing xxxx1.duckdns.org
+ Checking domain name(s) of existing cert... unchanged.
+ Checking expire date of existing cert...
+ Valid till Jul 2 20:21:36 2021 GMT Certificate will expire
(Less than 30 days). Renewing!
+ Signing domains...
+ Generating private key...
+ Generating signing request...
+ Requesting new certificate order from CA...
+ Received 1 authorizations URLs from the CA
+ Handling authorization for xxxx1.duckdns.org
+ 1 pending challenge(s)
+ Deploying challenge tokens...
KO + Responding to challenge for xxxx1.duckdns.org authorization...
+ Cleaning challenge tokens...
KO + Challenge validation has failed :(
ERROR: Challenge is invalid! (returned: invalid) (result: {
"type": "dns-01",
"status": "invalid",
"error": {
"type": "urn:ietf:params:acme:error:unauthorized",
"detail": "Incorrect TXT record \"\" found at _acme-challenge.xxxx1.duckdns.org",
"status": 403
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/14528376261/Wkmw1g",
"token": "ibo9wEAExxxxxxxxxBmQkDqaxxxxxxvGvsJDq7Ujt8",
"validated": "2021-07-04T11:10:32Z"
[13:15:37] INFO: OK
88.0.67.xx
NOCHANGE
[13:20:37] INFO: OK
88.0.67.xx
NOCHANGE
I can’t figure out what the problem is…
daniel_d
(Daniel D.)
July 4, 2021, 6:37pm
7
In the end I reinstalled the add-on and it works now.
I’ll have to set up a reminder 3 months from now, not to be taken by surprise.
Thanks!
Kitkat
(Amanda)
July 11, 2021, 8:07pm
8
Exactly the same problem every 3 months
Renewal never works and sadly this time, reinstalling the add-on hasn’t helped
blagojg
(Blagoj gjuzelov)
October 3, 2022, 7:39am
9
Same at me, three days and counting, I donate every month to duckdns, but no support !
Now started to switch back to NOIP
johnbull
(Johan Forsgard)
September 2, 2023, 10:19am
10
Bump on this
Anyone else having problems with DuckDNS today?
Mine works intermittently.
External IP and internal from LAN (or VPN) works fine.
I had the same experience on Tuesday this week.
aceindy
(Aceindy)
September 2, 2023, 11:51am
11
If you donate every month, why not buying your own domain ??
f.e. ha.blagojg.eu will cost you €7.99/yr at TransIP and works fine with Let’sEncrypt
johnbull
(Johan Forsgard)
September 2, 2023, 1:59pm
12
got an entry in the log now for the first time - unfortunately it doesn’t say me much more than it’s DuckDNS related…:
Logger: frontend.js.latest.202308021
Source: components/system_log/init .py:270
First occurred: 12:28:52 (1 occurrences)
Last logged: 12:28:52
https://xxxxxx.duckdns.org :YYYY/frontend_latest/core-WCIePk4vYnw.js:1:8205 Uncaught Error: Suspend promise not set
(xxxxxx=domain name, YYYY=port number)
johnbull
(Johan Forsgard)
September 2, 2023, 2:00pm
13
a few reports on updownradar and downdetector today
