Is Eufy Homebase 3 compatible with Home Assistant
I just can not get my two cameras working with Home Assistant. I have tried constantly for the last two weeks, and it is the only thing I can think of.
Have you had any luck with this? I’m having the same issue.
I recently upgraded from Eufy Cam 2 Pros w/Homebase 2 to Cam 3s w/Homebase 3 and my cameras cannot stream to HA.
“mse: sources unavailable” or “Can’t get URL for camera.backyard” is the error I receive when attempting to stream.
This is all setup via the instructions here: GitHub - fuatakgun/eufy_security: Home Assistant integration to manage Eufy Security devices as cameras, home base stations, doorbells, motion and contact sensors.
All worked fine with my Homebase 2 setup.
Have anyone looked at using RTSP as a workaround for HA integration?
Any update?
Is the integration working and sensor trigging?
Or is it not working at all…
I can live without the camera stream, but I have som sensors and automation triggered from using larm panel on and off etc and would need to upgrade to homebase 3, but I really need it to go work with home assistant
