Is ffmpeg pre-installed on hass.io?
As the title says, does hassio come with ffmpeg pre-installed?
I’m running hassio 0.73.2 on Ubuntu 16.04 and when i SSH into hassio (through the SSH - Secure Shell add-on) and run the following command:
ffmpeg -version
…I get this result:
zsh: command not found: ffmpeg
In my configuration I have added this:
ffmpeg:
camera:
  - platform: ffmpeg
    input: -rtsp_transport tcp -i rtsp://user:[email protected]/streaming/Channels/1
According to this link, hassio should come with ffmpeg installed and I only need to add ffmpeg to the configuration.
So, if ffmpeg is not installed on hassio, how do I install it?
I can install it on Ubuntu but hassio can’t access that, right?
Thanks!
The SSH add-on is running in a separate container from hassio AFAIK, and you won’t see all the commands available within hassio.
I might be wrong as that might have changed since I messed with it.
I was hoping it should be in this location on hassio:
I understand what you were looking for.
But when you SSH in, you’re not IN the hassio container. You’re in an SSH container. It’s a different container altogether.
Ok! :slight_smile:
What options do I have?
Can I access ffmpeg which I have installed on Ubuntu from the hassio container?
Or can I somehow access the hassio container and install ffmpeg there?
Hi again!
I have solved my problem and it was completely my fault :slight_smile:
Some days ago I created different VLANs for Home Assistant and my cameras och when looking at the firewall log there was some blocking.
Allowed the traffic and everything start working :slight_smile:
So this is what I’m using now and it’s working:
ffmpeg:
camera:
  - platform: ffmpeg
My solution to run commands installed on the host and that are not present in the Hassio image. Remember that the Hassio image for Raspberry Pi 4 is based on Alpine Linux. To install a package on Alpine, use the apk command. Example to install ffmpeg on this Linux:
$ apk add --no-cache ffmpeg
I circumvented the problem by running the command via SSH on the host using the “Terminal & SSH” add-on. Configure the add-on, then access the terminal and generate your identification keys:
$ ssh-keygen
(empty for the passphrase)
Then create the directory:
$ mkdir /config/.ssh
And copy the keys there:
$ cp /root/.ssh/id_rsa* /config/.ssh/
Perform an SSH access to your own host to record the data in known_hosts:
$ ssh root@[rasp_ip_address]
Once passwordless access is working, create the command you want to run in configuration.yaml:
   ffmpeg_version: ssh -i /config/.ssh/id_rsa -o 'StrictHostKeyChecking=no' root@[rasp_ip_address] "ffmpeg -version"
Restart Hassio.
Now just invoke the service: shell_command.ffmpeg_version
It’s tedious but it works.
thank you so much - threads and threads and threads for nothing. I could not get ffmpeg integration working (camera was just showing nothing) until I did such. Ultimately ffmpeg is not installed inside hassio.
