Anyone actually use the FixtSE mmwave sensor, https://fixtse.com/blog/esphome-mmwave-sensor? It has you install straight from the website then directly into HA and I can’t see any of the yaml; that makes me a bit nervous I guess.
Check out:
Helps create firmware and the plotly graph code so you get a nice real time plot of detected objects:
I’ll have to check this out, thanks.
