Is HACS safe to use
I want to protect my Information panel with Kiosk mode and saw that ‘Custom Header’ can fix it.
But it requires HACS to be installed … which I did.
After a while my Xiaomi Aqara temperatur sensors connected via deconz stopped working … they did not give me updated information. Before HACS they worked OK.
Is HACS reliable?
I guess I am not the only one who wants run an Information panel in Kiosk mode so I think that Kiosk mode should be implemented in Hassio (which is a great software) and not as it is now via HACS.
If I am wrong and have missed something please guide me in the right direction …
Two things:
  1. You don’t have to use HACS to install Custom Header
  2. HACS didn’t cause your problem
OK … I see there is a manual installation also … will try that.
You mention that HACS didn’t cause my problem … but the problems occurred after HACS was installed.
Correlation does not equal causation.
I tried to manually install it …
The ‘custom-header.js’ is stored in /config/www/custom-lovelace/compact-custom-header
$ ls -l /root/config/www/custom-lovelace/compact-custom-header
-rw-r–r-- 1 root root 105992 May 3 15:33 custom-header.js
and I entered in Configuration/Lovelace Dashboards/Resources as:
Url
/config/www/custom-lovelace/compact-custom-header/custom-header.js
Resource type
JavaScript Module
rebooted but no Custom Header in the UI menu.
When I entered
lovelace:
  mode: yaml
# Add-On for lovelace
  resources:
    - url: /local/custom-lovelace/compact-custom-header/custom-header.js
      type: module
config $
it worked … strange !
