Hi.
I have got the following on the hass.io system log. Is this telling me that for some reason hass.io has restarted and if so how do I find out what is causing the problem.
Thanks.
19-09-25 15:30:47 INFO (MainThread) [__main__] Initialize Hass.io setup
19-09-25 15:30:47 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/armv7-hassio-supervisor with version 189
19-09-25 15:30:47 INFO (SyncWorker_0) [hassio.docker.supervisor] Connect Supervisor to Hass.io Network
19-09-25 15:30:48 INFO (SyncWorker_0) [hassio.docker.interface] Cleanup images: ['homeassistant/armv7-hassio-supervisor:188']
19-09-25 15:30:49 INFO (MainThread) [__main__] Setup HassIO
19-09-25 15:30:49 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
19-09-25 15:30:49 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
19-09-25 15:30:49 WARNING (MainThread) [hassio.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
19-09-25 15:30:49 WARNING (MainThread) [hassio.dbus.nmi_dns] No DnsManager support on the host. Local DNS functions have been disabled.
19-09-25 15:30:49 INFO (MainThread) [hassio.host.info] Update local host information
19-09-25 15:30:49 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-09-25 15:30:49 INFO (MainThread) [hassio.host.services] Update service information
19-09-25 15:30:49 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-09-25 15:30:50 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
19-09-25 15:30:50 INFO (MainThread) [hassio.host.services] Reload local service hassio-apparmor.service
19-09-25 15:30:50 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
19-09-25 15:30:50 INFO (SyncWorker_1) [hassio.docker.interface] Attach to homeassistant/armv7-hassio-dns with version 1
19-09-25 15:30:50 INFO (MainThread) [hassio.dns] Update resolv from Supervisor
19-09-25 15:30:50 INFO (MainThread) [hassio.misc.forwarder] Start DNS port forwarding to 172.30.32.3
19-09-25 15:30:50 INFO (SyncWorker_2) [hassio.docker.interface] Stop hassio_dns application
19-09-25 15:30:52 INFO (SyncWorker_2) [hassio.docker.interface] Clean hassio_dns application
19-09-25 15:30:52 INFO (MainThread) [hassio.dns] Start CoreDNS plugin
19-09-25 15:30:55 INFO (SyncWorker_0) [hassio.docker.dns] Start DNS homeassistant/armv7-hassio-dns with version 1
19-09-25 15:30:55 INFO (SyncWorker_1) [hassio.docker.interface] Attach to homeassistant/raspberrypi3-homeassistant with version 0.99.2
19-09-25 15:30:56 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/a0d7b954 repository
19-09-25 15:30:56 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/cebe7a76 repository
19-09-25 15:30:56 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/core repository
19-09-25 15:30:57 INFO (MainThread) [hassio.store] Load add-ons from store: 61 all - 61 new - 0 remove
19-09-25 15:30:57 INFO (MainThread) [hassio.addons] Found 6 installed add-ons
19-09-25 15:30:57 INFO (SyncWorker_6) [hassio.docker.interface] Attach to homeassistant/armv7-addon-mosquitto with version 5.0
19-09-25 15:30:57 INFO (SyncWorker_7) [hassio.docker.interface] Attach to hassioaddons/node-red-armv7 with version 4.1.1
19-09-25 15:30:57 INFO (SyncWorker_8) [hassio.docker.interface] Attach to homeassistant/armv7-addon-mariadb with version 1.2
19-09-25 15:30:57 INFO (SyncWorker_6) [hassio.docker.interface] Attach to sabeechen/hassio-google-drive-backup-armv7 with version 0.98.3
19-09-25 15:30:57 INFO (SyncWorker_14) [hassio.docker.interface] Attach to homeassistant/armhf-addon-deconz with version 3.6
19-09-25 15:30:57 INFO (SyncWorker_15) [hassio.docker.interface] Attach to homeassistant/armv7-addon-samba with version 8.1
19-09-25 15:30:57 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
19-09-25 15:30:57 INFO (MainThread) [hassio.snapshots] Found 4 snapshot files
19-09-25 15:30:57 INFO (MainThread) [hassio.discovery] Load 2 messages
19-09-25 15:30:57 INFO (MainThread) [hassio.ingress] Load 3 ingress session
19-09-25 15:30:58 INFO (MainThread) [hassio.secrets] Load Home Assistant secrets: 14
19-09-25 15:30:58 INFO (MainThread) [__main__] Run Hass.io
19-09-25 15:30:58 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
19-09-25 15:30:58 INFO (MainThread) [hassio.addons] Phase 'initialize' start 0 add-ons
19-09-25 15:30:58 INFO (MainThread) [hassio.core] Hass.io reboot detected
19-09-25 15:30:58 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
19-09-25 15:30:58 INFO (MainThread) [hassio.core] Hass.io is up and running
19-09-25 15:30:59 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-09-25 15:30:59 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-09-25 15:30:59 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
19-09-25 15:30:59 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request running
