Hi, I’m trying to install the latest version on a Raspberry Pi 3 Model B with 1GB RAM but I’m still unsuccessful.
I can download the image according to the official link (Raspberry Pi - Home Assistant) or using the image software for raspberry pi and even so, the installation does not proceed.
More precisely, I am having difficulty installing it once the web service becomes available (http://X.X.X.X:8123). Is it still possible to install this version on the Raspberry Pi 3?
Notes:
I cannot exit the 20 minute screen even though several hours have passed.
correct power suply (5v,3a).
correct and healtly sd card.
In the worst case, even if it is not recommended, I will test versions below this one.
I recently installed on a 3B+ which has 1gb and had no issues. Oddly I cannot update, always fails. It’s slow and a good idea to add a swap file through the SSH add on. For me it’s just a backup system of my main x86 install.
Agree if rpi is only instance. Since early 2024 updates became difficult and with 2025 it’s just not happening. Still functions normally for data acquisition and control so I keep it running as a backup.
This thread is about running HA on a 3B with 1GB today, you just stated that you have major issues with the exact setup? I don’t quite get your argument here.
Nothing to do with belief or whether it is a good option. I responded to the OP’s question with my experience. I agree rpi is a poor platform now and it’s not my primary HA instance.
Is this something to argue then? You don’t run your main HA on it, you have issues updating it, and several people state that 1GB is too little today. You also state that you agree running a 3B with 1GB RAM as a single instance is not a good idea.
The bottom line is that running an average HA install today with only 1GB will give you issues, and unless you take the “is installing still possible” literally and jut focus on the installation part it is not a viable option.
While it might be poorly performing; add at least a 3GB swap (you can create a swap file). Disable all tmpfs file systems except for /dev/shm and set a limit for shm.
