Hey everyone!
This is a bit of an existencial crisis kind of post more than a technical difficulty one. Hope you can help however you can.
So, I started exploring HA on my own in Dec 2021. Got myself a Pi 4 which is connected with a cable to my router. At that time I was especially interested in having my current Tuya/Smartlife devices working within HA. Mainly wondered whether it would be possible to have motion sensors triggering lights a bit faster, or just connect devices of different manufactures in a single automation process. I managed to configure 1 light from Tuya in HA. That was sort of my proof of concept.
Then life happened and I didn’t have the time (or will) to dedicate to HA for an entire year. The whole Local Tuya process is a bit of a cumbersome one, and not exactly bulletproof, which didn’t help either.
Either way, recently, in Dec 2022 I got plenty of time at hands and decided to take my HA to the next step. Updated HA itself, along with every extension that needed an update. Didn’t really had anything going on so the risk of having to format it and start from scratch was worth it.
By January I had configure all but 1 out of +20 Tuya devices in my HA — the 1 that didn’t was refusing to connect due to some “missing datapoints” of some sort. Tried power cycling it. Triple checked the IP was correct. Tried multiple protocols. Tried moving the router closer to it. Nothing seemed to work. The device was working fine through the Smartlife app though. And Google Home too.
Also managed to set up my Eufy cameras and homebase, making it possible to finally connect Tuya with Eufy in an automation that would flash some indoor lights after dark, when motion is sensed outside. This worked for a single day only.
Even managed to set up an automation for both my and my wife’s phones so that the Eufy homebase would disarm the alarm when both of us were at home. Which also only worked for a day.
The day after, all of a sudden, HA became wildly unresponsive. Reboots would take several minutes instead of roughly 1 minute. HACS rarely completely loaded — the icon on the sidebar would usually be hidden next to the label.
The Eufy integration stopped working.
The Logs mentioned “rate limit” with GitHub. I searched a lot and read a lot of threads in here. Including one where someone mentioned GH had an API endpoint where we would check how many requests we had left. It was all absolutely fine. Not only that, even hours and days after these log messages first pop up, it would still be unresponsive.
Did plenty of reboots. They all took several minutes.
Hassio alone was taking +3 minutes to load, with log messages such as:
Waiting on integrations to complete setup: hassio
At some point uninstalled the Eufy integration and it didn’t help. When I tried to reinstall it, got no luck as it wouldn’t go past the loading screen — presumably because of the rate limiting again.
Which means I can’t update anything right now.
To me, it all felt like this happened all of a sudden. But I may have tweaked or installed something that I can’t remember and could have been messing up something, it would only be fair to thing so.
This morning, without any progress, I decided to restore a backup 2 weeks old. I’m absolutely certain that 2 weeks ago it was working fine, even though it didn’t have some automations/integrations configured — such as the Eufy one.
It’s behaving in a very similar way. Hassio still takes a long time to run, but it’s slightly faster now, due to not all integrations being installed, I suppose. But it’s still struggling with rate limits, and that’s likely what’s causing all the delays.
Then I tried an yet earlier backup. Can’t tell any difference either. It’s so far back in time at this point that I would have to reconfigure everything I had previously done. All Tuya devices/automations. All Eufy devices/automations. Remote access. Our phones configured, etc. Might as well start from scratch!
If you’re still here — thank you! — the next bit is where you come in.
At this point I’m wondering if all this is worth it.
How has been your experience both while setting up as well as after it?
Do you usually install system and integration updates as they come out? Do you fix all versions and consider it “done” for life?
Do you have issues when installing new versions?
If you don’t update, do you have issues that come all of a sudden?
I can see HA being extremely useful, don’t get me wrong! But I’m not sure I want to be eternally tinkering with it just to make sure my house is properly functioning.
