I have two Miboxer WL5 LED strip controllers laying around. I know they are not based on ESP8266 nor ESP32. They are based on a “WR3” chip, which has a form factor similar to ESP-12e plus an additional N76E003AT20 MCU chip
I’ve seen a comment of someone who replaced the “WR3” chip with an ESP-12e and was able to enable some functions on Tasmota’s Github: Flash Mi-Light WL5 with Tasmota? · Issue #7385 · arendst/Tasmota · GitHub
That is the only mention I found to that hack. Do you think it will be possible to bring those devices to the light side of home automation?
i use the Mi-Light (miboxer) WiFi bridge to control the Miboxer LED controllers. That way it is compatible with HA thru the LimitlessLED integration. Works flawlesly here.
No need to DIY anything
Thanks for the suggestion. I’m not using them right now. I only want to explore if it will be feasible to use them with ESPHome. All my switches and lights run on it, and I want to avoid fragmentation on the system.
Sorry to reopen this but it’s related to this thread.
I used @Flanagun’s template. I have got an ESP12-S transplanted in the WL5 and got Tasmota on it working (sort of).
I need help getting RGB+CCT working with this.
I have tried this code from another template (linked below) and it sort of works. I can control RGB & CCT separately.
But when I am on an RGB value, and select an CCT value, the mode changes fine. But when I am on a CCT value and select an RGB value. The mode is stuck on the CCT mode.
