Is it my Pi that's smoked? Home Assistant doesn't get beyond 'preparing'
I’m running a Pi 3 B+ with a good quality, new, branded high speed SD card.
I’ve twice now tried to install Home Assistant on the Pi’s SD card. Firstly I tried haos_rpi3-64-9.5.img but I got into a restart loop so I thought I’d try an older image to see if it too suffered from the same problem. So I downloaded haos_rpi3-9.3.img.xz. Now I get the below log, and seemingly another loop? I’m really confused. I mean clearly Home Assistant is starting…I can ping it, obviously, I can access the supervisor port:
Supervisor: Connected
Supported: Supported
Healthy: Healthy
but something is clearly going wrong…?? It’s an ethernet connection too, not wifi.
Any ideas?? At this point it looks like maybe the Pi’s hardware is somehow broken/defective??
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[18:50:20] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
s6-rc: info: service legacy-services successfully started
[18:50:20] INFO: Starting local supervisor watchdog...
23-03-11 18:50:35 INFO (MainThread) [__main__] Initializing Supervisor setup
23-03-11 18:50:35 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, creating a new network
23-03-11 18:50:36 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
23-03-11 18:50:36 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: raspberrypi3
23-03-11 18:50:36 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/armv7-hassio-supervisor with version 2022.10.0
23-03-11 18:50:36 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
23-03-11 18:50:38 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
23-03-11 18:50:38 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-03-11 18:50:38 INFO (MainThread) [__main__] Setting up Supervisor
23-03-11 18:50:39 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
23-03-11 18:50:39 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
23-03-11 18:50:39 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
23-03-11 18:50:39 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
23-03-11 18:50:39 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
23-03-11 18:50:39 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
23-03-11 18:50:39 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
23-03-11 18:50:39 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
23-03-11 18:50:39 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
23-03-11 18:50:39 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
23-03-11 18:50:39 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
23-03-11 18:50:41 INFO (MainThread) [supervisor.host.services] Updating service information
23-03-11 18:50:41 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-03-11 18:50:42 INFO (MainThread) [supervisor.host.network] Updating local network information
23-03-11 18:50:42 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
23-03-11 18:50:43 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
23-03-11 18:50:43 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/armv7-hassio-cli versions: [<AwesomeVersion CalVer '2022.08.0'>]
23-03-11 18:50:43 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/armv7-hassio-cli with version 2022.08.0
23-03-11 18:50:43 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
23-03-11 18:50:48 INFO (SyncWorker_0) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/armv7-hassio-cli with version 2022.08.0 - 172.30.32.5
23-03-11 18:50:49 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/armv7-hassio-dns versions: [<AwesomeVersion CalVer '2022.04.1'>]
23-03-11 18:50:49 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/armv7-hassio-dns with version 2022.04.1
23-03-11 18:50:49 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
23-03-11 18:50:55 INFO (SyncWorker_0) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/armv7-hassio-dns with version 2022.04.1 - 172.30.32.3
23-03-11 18:50:55 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-03-11 18:50:55 INFO (SyncWorker_1) [supervisor.docker.interface] Found ghcr.io/home-assistant/armv7-hassio-audio versions: [<AwesomeVersion CalVer '2022.07.0'>]
23-03-11 18:50:55 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/armv7-hassio-audio with version 2022.07.0
23-03-11 18:50:55 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
23-03-11 18:51:00 INFO (SyncWorker_0) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/armv7-hassio-audio with version 2022.07.0 - 172.30.32.4
23-03-11 18:51:01 INFO (SyncWorker_1) [supervisor.docker.interface] Found ghcr.io/home-assistant/armv7-hassio-observer versions: [<AwesomeVersion CalVer '2021.10.0'>]
23-03-11 18:51:01 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/armv7-hassio-observer with version 2021.10.0
23-03-11 18:51:01 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
23-03-11 18:51:08 INFO (SyncWorker_0) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/armv7-hassio-observer with version 2021.10.0 - 172.30.32.6
23-03-11 18:51:08 INFO (SyncWorker_1) [supervisor.docker.interface] Found ghcr.io/home-assistant/armv7-hassio-multicast versions: [<AwesomeVersion CalVer '2022.02.0'>]
23-03-11 18:51:08 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/armv7-hassio-multicast with version 2022.02.0
23-03-11 18:51:08 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
23-03-11 18:51:12 INFO (SyncWorker_0) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/armv7-hassio-multicast with version 2022.02.0 - Host
23-03-11 18:51:12 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-03-11 18:51:16 INFO (MainThread) [supervisor.plugins.manager] cli does not have the latest version 2022.11.0, updating
23-03-11 18:51:16 WARNING (MainThread) [supervisor.jobs] 'PluginCli.update' blocked from execution, supervisor needs to be updated first
23-03-11 18:51:16 ERROR (MainThread) [supervisor.plugins.manager] Can't update cli to 2022.11.0, the Supervisor healthy could be compromised!
23-03-11 18:51:16 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_UPDATE - ContextType.PLUGIN / cli
23-03-11 18:51:16 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.UPDATE_FAILED - ContextType.PLUGIN / cli
23-03-11 18:51:16 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
23-03-11 18:51:16 INFO (SyncWorker_0) [supervisor.docker.interface] No version found for ghcr.io/home-assistant/raspberrypi3-homeassistant
23-03-11 18:51:16 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/raspberrypi3-homeassistant found.
23-03-11 18:51:16 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi3-homeassistant with version landingpage
23-03-11 18:51:16 INFO (MainThread) [supervisor.homeassistant.core] Using preinstalled landingpage
23-03-11 18:51:16 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
23-03-11 18:51:16 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
23-03-11 18:51:19 INFO (SyncWorker_1) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/raspberrypi3-homeassistant with version landingpage
23-03-11 18:51:19 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 9.3 / BootSlot A
23-03-11 18:51:19 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
23-03-11 18:51:19 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
23-03-11 18:51:19 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
23-03-11 18:51:28 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/core/matter_server/config.yaml: Service matter not found @ data['discovery'][0]. Got 'matter'
23-03-11 18:51:28 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/core/silabs-multiprotocol/config.yaml: Service otbr not found @ data['discovery'][0]. Got 'otbr'
23-03-11 18:51:28 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/git/5c53de3b/esphome-dev/config.yaml: Service esphome not found @ data['discovery'][0]. Got 'esphome'
23-03-11 18:51:28 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/git/5c53de3b/esphome-beta/config.yaml: Service esphome not found @ data['discovery'][0]. Got 'esphome'
23-03-11 18:51:28 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/git/5c53de3b/esphome/config.yaml: Service esphome not found @ data['discovery'][0]. Got 'esphome'
23-03-11 18:51:30 INFO (MainThread) [supervisor.store] Loading add-ons from store: 63 all - 63 new - 0 remove
23-03-11 18:51:30 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
23-03-11 18:51:30 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-03-11 18:51:30 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
23-03-11 18:51:30 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
23-03-11 18:51:30 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
23-03-11 18:51:30 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-03-11 18:51:30 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
23-03-11 18:51:30 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-03-11 18:51:30 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
23-03-11 18:51:30 INFO (MainThread) [__main__] Running Supervisor
23-03-11 18:51:30 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
23-03-11 18:51:30 INFO (MainThread) [supervisor.supervisor] Fetching AppArmor profile https://version.home-assistant.io/apparmor.txt
23-03-11 18:51:32 INFO (MainThread) [supervisor.host.apparmor] Adding/updating AppArmor profile: hassio-supervisor
23-03-11 18:51:33 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2023.03.1
23-03-11 18:51:33 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/armv7-hassio-supervisor with tag 2023.03.1.
[18:56:14] INFO: Using udev information from host
[18:56:15] INFO: Starting local supervisor watchdog...
23-03-11 18:56:21 INFO (MainThread) [__main__] Initializing Supervisor setup
23-03-11 18:56:21 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: raspberrypi3
23-03-11 18:56:21 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/armv7-hassio-supervisor with version 2023.03.1
23-03-11 18:56:21 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
23-03-11 18:56:22 INFO (SyncWorker_0) [supervisor.docker.interface] Cleanup images: ['ghcr.io/home-assistant/armv7-hassio-supervisor:2022.10.0']
23-03-11 18:56:26 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
23-03-11 18:56:26 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-03-11 18:56:26 INFO (MainThread) [__main__] Setting up Supervisor
23-03-11 18:56:26 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
23-03-11 18:56:27 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
23-03-11 18:56:27 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
23-03-11 18:56:27 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
23-03-11 18:56:27 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
23-03-11 18:56:27 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
23-03-11 18:56:27 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
23-03-11 18:56:27 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
23-03-11 18:56:27 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
23-03-11 18:56:27 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
23-03-11 18:56:27 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
23-03-11 18:56:29 INFO (MainThread) [supervisor.host.services] Updating service information
23-03-11 18:56:29 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-03-11 18:56:29 INFO (MainThread) [supervisor.host.network] Updating local network information
23-03-11 18:56:30 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
23-03-11 18:56:30 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
23-03-11 18:56:30 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/armv7-hassio-cli with version 2022.08.0
23-03-11 18:56:30 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/armv7-hassio-dns with version 2022.04.1
23-03-11 18:56:30 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-03-11 18:56:30 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/armv7-hassio-audio with version 2022.07.0
23-03-11 18:56:30 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/armv7-hassio-observer with version 2021.10.0
23-03-11 18:56:30 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/armv7-hassio-multicast with version 2022.02.0
23-03-11 18:56:30 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-03-11 18:56:32 INFO (MainThread) [supervisor.plugins.manager] cli does not have the latest version 2022.11.0, updating
23-03-11 18:56:32 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/armv7-hassio-cli:2022.08.0 to ghcr.io/home-assistant/armv7-hassio-cli:2022.11.0
23-03-11 18:56:32 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/armv7-hassio-cli with tag 2022.11.0.
Might want to try another 32g SD card. And try another power supply.
Thanks. Actually just after I posted, THIS installation booted fine, despite the apparent similarity to the boot loop in the log above from the one I linked to which never booted.
So there’s an issue for sure with haos_rpi3-64-9.5 and the Pi3B+…
Interesting. Might want to see if there are any issues over on GitHub.
