Is it possible to access to data of HEATit device ? (smoke detector)
Hello !
I check on the DEVICES LIST ( Integrations - Home Assistant ) and I don’t find the HEATit brand.
Where I live, I need to connect fire detector to the 230v (new law in the country).
So I found this model : https://www.heatit.com/z-wave/heatit-z-smoke-ac/ (smoke detection, heat detection, motion detection, emergency light, etc).
Is seems to be a very nice device.
But, is it possible to use it with Home Assistant ?
To see datas (alarm, temperature, detected motion) or use feature (use the motion detector to activate an notification, activate the light on scenarios, etc).
Thanks a lot ! :slight_smile:
Please, do you have any idea?
Thanks :slight_smile:
I just received the answer from HEATit :slight_smile:
“I can’t answer that seeing as we don’t test our products on OpenZWAVE gateways.”
:frowning:
Hi. I have 12 of these installed so yes it’s possible with the new Zwave-JS.
By lack of time, I didn’t yet migrate to the new zWave.
Can you acces to all features ? (smoke alerte, heat alert, motion sensor, use the light, etc) ?
HeatIT is still not in this list :
Hi
It’s not an integration but rather supported via Zwave-JS. You can view supported devices here https://devices.zwave-js.io/
Below you can see the entities exposed by default. One thing I have noticed is that the temperature is a constant 3-4 degrees above what is measured by thermostats in the room.
I use the motion detection to turn on/off lights
Thanks a lot !! So soon I will order 2.
do you use the model with battery or AC ?
If battery, is it lasting ore than 1 year?
Hi
I have all of mine running on AC.
