Is it possible to add UV index attribute to weather template?
I’ve been looking through the documentation and cannot figure out how to do it. Is it possible that it just isn’t supported? In that case, should I open a feature request or I’m being stupid and there’s a reason this cannot be supported?
My goal is to have a template weather entity that serves as an “aggregator” of a few different ones and then base all my dashboards and automations on that aggergator entity. This way if I ever change which providers I use for different pieces of weather info, I do not need to update anything other than the template weather sensor.
I checked the Template Weather integration’s documentation and its source code and, like you said, there’s no support for UV index.
I suggest you create a Feature Request.
Even though the Template Weather integration creates a weather entity based on the ‘building block’ Weather integration, that ‘building block’ states that not all of its attributes may be present in entities created by other weather-provider integrations.
