Is it possible to bypass the regulation of a AVM FRITZ!DECT 301?
I want to buy AVM FRITZ! DECT 301.
Is it possible to regulate the thermostat manually and set the valve from 0% to 100%?
Or can I just set the temperature?
Hi! I’m using these Thermostate since a couple of years and I’m really happy. You can only set the target temperature. What do you mean by 0-100%?
The biggest drawback is, that changes fromm HA are only pulled every couple of minutes by the device.
